Seeing as the unit uses a cathodic tube rectifier (6CA4) and all of the tubes will begin conducting at almost the same time,you won't experience the voltage surge normally experienced with a filamentary or solid state rectifier.Also,the maximum circuit voltage appears to be 245V. So,to answer your actual question,yes,your 400 volt capacitors will work without issue in this application.
