CR-2020 Service Bulletin Guidance
Discussion in 'Yamaha' started by Hi Fi Fan, Jul 30, 2018.
  1. Hi Fi Fan
    Hi Fi Fan AK Subscriber Subscriber
    62
    Hi everyone, new member here.
    I just purchased a working CR-2020. I opened it up yesterday to clean pots, etc. and check to see if the Service Bulletins have been performed. I have modest to average electronic repair skills.
    The power switch was shorted, I rebuilt it and added the jumper as advised in the SB. Works great now.
    I inspected the electrolytic cap board to see if that SB work has been done. There is some scorching on the board so part locations are difficult to read. There are a few components raised up off the board and the soldering for these parts appears non-factory. Can anyone tell from the attached photos whether the subject SB components have already been replaced?
    http://audiokarma.org/forums/index.php?media/img_1787.15983/
    http://audiokarma.org/forums/index.php?media/img_1790.15984/
    The 2 transistors on the power supply board referenced in the SB appear to me to be original based on the part number. I touched up the solder points and am wondering if these transistors should to be replaced as a matter of course or can I just add larger heat sinks? A quick check online suggested that these parts may have been obsoleted.
    http://audiokarma.org/forums/index.php?media/img_1796.15985/
    Thanks is advance.
  2. avionic
    46,508
    Fort Dodge, Iowa
    Welcome to AK... Does not look like SB's have been complied with. The resistors in question look OEM to me.
    Hi Fi Fan likes this.
  3. avionic
    46,508
    Fort Dodge, Iowa
    Those have been obsolete for a long time... 5-10 years or more..
  4. avionic
    46,508
    Fort Dodge, Iowa
  5. avionic
    46,508
    Fort Dodge, Iowa
  6. Hi Fi Fan
    62
    Thanks a lot for the help everyone, I appreciate it!!!
    Do any of the capacitors need to be discharged before doing the SBs?
    Thank you!
  7. Hi Fi Fan
    62
    "These are no longer available so either use a TIP41C or 2SD613."
    Awesome, is either TIP41C or 2SD613 preferred?
    Thank you.
  8. avionic
    46,508
    Fort Dodge, Iowa
    Which ever is easiest to obtain. . The 2SD613 is probably obsolete as well.
  9. Hi Fi Fan
    62
    Thank you!
  10. avionic
    46,508
    Fort Dodge, Iowa
    Probably wouldn't hurt to check the two bigg'ns.
  11. Hi Fi Fan
    62
    My thoughts exactly!
    Newbie here, do I just short one pin to ground and then recheck voltage?
    Thank you.
  12. Hi Fi Fan
    62
  13. Oilmaster
    Oilmaster Drillers go deeper Subscriber
    1,286
    Paris & The Hague
    For your absorption regarding the SB resistors :
    http://audiokarma.org/forums/index....-41vdc-on-outputs.787761/page-3#post-10992603
    KSD526 (available with most suppliers) is a decent sub for TR712/715
    Having adequate cooling for these trannies is typical service topic #2 for this unit.
    Some inspiration here:
    http://audiokarma.org/forums/index....toration-guidance.798122/page-6#post-11128538
    Those purple sleeve capacitor(s) should really be replaced; they age very badly, and cause all kind of issues such as a non-engaging relay.
    Talking about it, the relay would be typically replaced (by Omron MY2-DC12) as well when your donw there.
  14. Hi Fi Fan
    62
    Thanks I will check those links out, appreciate the help!
  15. avionic
    46,508
    Fort Dodge, Iowa
  16. Hi Fi Fan
    62
  17. avionic
    46,508
    Fort Dodge, Iowa
  18. Hi Fi Fan
    62
    Thank you, ordering parts today!
  19. Oilmaster
    1,286
    Paris & The Hague
    What really really really surprises me is that your unit is seemingly originally missing fusible resistor FR803 !
    That is where that black wire jumper is on your board.
    I think 'originally' as your PCB has not even the resistor value printed on it as it usually does.
    That is a first off!
    What is the serial number of the unit?
  20. Hi Fi Fan
    62
    Thanks a lot. I noticed that too while I was inspecting these boards, "hmm, weird jumper wire here." Is it advisable to add a resistor there? If so, is it a 10ohm 220ma as shown?
    Serial is 02922, see attached.
    Without going nuts as my skills are limited are there any other "should do" parts replacements on these boards for reliability? I found another thread that suggested another 4 capacitors:
    http://audiokarma.org/forums/index.php?threads/yamaha-cr-2020-faulty-no-sound-sb-mods.291232/
    "In addition to the service bulletin repair parts as listed in the first post, i also replaced the two 1000mfd/50 capacitors with 63v/1000mfd capacitors per merrylanders advice and two 1000pf/100v ceramic capacitors behind the SD234 transistors."
    Thank you!
