merrylander
AK Member
The actual service bulletins are posted here somewhere but when I have a chance I'll send them to Sigurd.
In the first photo I have removed the two screws that hold down the relay board and slid it off the six pins that connect it to the power board.
Note that in order to do this the two blue wires must be cut. Since I need to be able to lift out the power board the red and black wires must be cut also.
In the second photo I have lifted the relay board to one side to show the brackets that hold down the power board. Please note that these three brackets all heve keyhole shaped mountings, so the screws do not need to be removed, if you do remove them when it comes time to replace the brackets those nearby may well learn some new phrases.
In the third photo the brackets are out and I can now lift the power board out so that I can change the parts.
