Hi,
I have a CR-2020 in what I would consider to be excellent condition. I purchased it used and was told by the seller that it had the service bulletin modifications done.
There is intermittent static in the right channel. It's not there when initially powered on and usually appears within 10 to 30 minutes. A slight knock to the case will often fix it temporarily. It seems to me that once the unit is on for about an hour the static disappears.
The static is audible through headphones and moves to the right channel (speakers or headphones) when the channels are reversed using the Mode dial. The static is also audible using an external preamp.
At one point the static started almost at startup and would cease if the one of the FM Mute or Blend buttons were pressed (I forget which one). I brought it for service and they fixed the static associated with the FM circuitry but they didn't address the remaining static issue. I'm going to have to bring it back to the technician for that.
The place I brought it to told me they don't do refurbishing--only repairs to obvious problems.
I've read that in order for these units to perform their best they likely need to be refurbished.
So, I'm wondering if this is something that I could possibly do on my own. I don't know much about working with electronics but I'm mechanically inclined and capable of researching what would need to be done.
I'm looking for opinions on this and wondering if there are an resources for learning how to go about planning refurbishing this receiver; i.e, conducting an inventory of parts to be replaced, identifying them and obtaining replacement parts.
On the other hand, I wonder if the necessity of refurbishing is overstated and whether there is any real potential for an audible difference to be heard?
To me this is a great sounding receiver. I think it compares favorably to most of the better equipment I've owned. I really want to keep this unit in good working order and take whatever steps I can to keep it that way. I'm really thinking of selling my other amps and preamps and sticking with the CR-2020.
I'd really like to find a way to do some work myself. I'd like to pick up a CA-1010 or CA-2010 at some point.
I suppose this is a good a place to ask for opinions on the best sounding vintage Yamaha receivers and integrated amplifiers.
Any thoughts appreciated.
Thanks
Thanks
