CR-2020 trying to get up and running
Discussion in 'Yamaha' started by vinyl fiend, Apr 24, 2016.
  1. vinyl fiend
    vinyl fiend Active Member
    415
    Newburgh, NY
    I have a CR-2020. When I lift the relay a little bit to a certain position, it clicks on and seems to work fine. Not sure if the board is warped or if it's a power issue. How do I check DC before the relay? Also, I haven't done the service upgrades. Is this correct? : Any suggestions are much appreciated.
    (2) 33ohm 3 1/4 watt ohmites
    (2) 22 ohm 3 1/4 watt ohmites
    (2) 2SD525 transistors
  2. avionic
    45,542
    Fort Dodge, Iowa
    I'd be looking for cold solder connections on that power supply board. Especially under those heatsink mounted TO-220 transistors leads.(2SD525 transistors)
  3. Electone
    Electone Well-Known Member
    768
    London, Ontario, Canada
    That whole board is constantly being cooked. Best to completely remove it and as Avionic said, check all solder joints. Be careful when lifting it - the connected wires will be brittle and can snap off. Ask me how i know...:oops:.
  4. HypnoToad
    HypnoToad Ms Puss Puss Subscriber
    6,107
    Melbourne, Australia
    I had relay clicking in and out problems on my CR1020, I recapped the PSU board, the one with the relay and once I removed the fuse and put it back in, it all worked fine, I also replaced the heat sinked transistors with modern counterparts as if I tapped on them lightly the relay would click out and in. It hasn't missed a beat since. Check all the solder joints like Avionic said and also the connector between the PSU board and the Capacitor board as well.
  5. clearsoft
    clearsoft New Member
    9
    I had a similar issue with my CR-1020. Many many hours of troubleshooting, so wanted to share here in the hopes of saving others some heartburn.
    After a full power supply recap (both pcbs) and power transistor upgrade to higher voltage TIP31C in the supply, the protection relay would not fire. The -25V output sat at -10V. Cleaned the flux and grime off the bottom side the PCB and the output went to +6V. Disconnected the two purple wires from the -25V post to eliminate loading. No improvement. Removed and retested all 4 transistors; junctions not shorted nor open.
    Decided to look at the .01uF capacitors. In circuit across the terminals, the one on the -25V supply measured 6 kOhms whereas the one in the +25V supply measured 3 megohms. Pulled the caps; neither was leaky. Pulled the 4 transistors again. Still 6 KOhms...strange.
    Used flux remover to clean the top side of the PCB around the .01uF cap locations, removing glue residue around the heatsinks. Resistance now 2 megohms. Apparently the glue that Yamaha used was not electrically benign and the -25V supply is extra sensitive to leakage current (check out the circuit topology).
    Reinstalled all components. Reconnected all wires. Voltages perfect. Relay works.
    —Ed
