CR 2040 No Lights, No Relay Click
Discussion in 'Yamaha' started by absolve2525, Jul 16, 2018.
  1. absolve2525
    absolve2525 Super Member
    2,107
    Grrr.... I was attempting to replace some dimming lamps in the meters, and accidentally tapped the long skinny board, with the four top lamps, against the main heat sink. Saw a spark, now no bulbs light or meters work. I replaced and checked bulbs. Perhaps a transistor blew? I only see a main fuse in the back. Are there others? The amp section is still working, as I can measure DC offset and bias, which aren't too high for the relay to not engage. Thanks for suggestions!
  2. petehall347
    28,247
    uk.. the middle bit
    follow orange and yellow wires from transformer and look for the fuses .
    absolve2525 likes this.
  3. petehall347
    28,247
    uk.. the middle bit
    if they are both good there is a resistor ladder . all 1k .
  4. petehall347
    28,247
    uk.. the middle bit
    look at the schematic it isnt hard to follow as i can do it easily .
  5. avionic
    45,489
    Fort Dodge, Iowa
    Inside are two fuses F901 and F902 ( 3A / 250v).
  6. avionic
    45,489
    Fort Dodge, Iowa
    Located on the power supply board right next to the Bridged rectifier. The same board has the loudness control and headphone jacks mounted to it. The protect relay is also on that board.
  7. petehall347
    28,247
    uk.. the middle bit
    has to be those fuses .
  8. absolve2525
    2,107
    Thanks guys! Found the blown fuse!
  9. absolve2525
    2,107
    Well crap. It's still burning up the left fuse. I used lamps that I bought years ago for a big Kenwood KR model. I assumed the voltage was the same, but perhaps they were not? I cut off all the dial lamps, disconnected the four top lamps. Now it's just the tuner lamp, which I replaced also with the Kenwood lamp. Still slowly blows the fuse.
  10. petehall347
    28,247
    uk.. the middle bit
    check the wiring first . and diodes to be sure . then put old lamps back if they were working but i guess not .. the sparking bit stands out to me .
    or best disconnect the lamps completely to save chasing in the wrong direction .
    absolve2525 and avionic like this.
  11. avionic
    45,489
    Fort Dodge, Iowa
    D912 perhaps.
    Just in case............................:D
    BAV21 or equivalent.
  12. absolve2525
    2,107
    I disconnected all the lamps, and the left fuse still slowly heats up. Sooo I will try checking the diodes. Thanks!
  13. absolve2525
    2,107
    Do you know if there's a parts list to show what diodes I would need? I haven't replaced many diodes before. Thanks!
  14. avionic
    45,489
    Fort Dodge, Iowa
    Yes. The manual calls it a schematic.
    Bratwurst7s likes this.
  15. absolve2525
    2,107
    Cool, I didn't know for sure if type was shown. I'll check and come back with an update. Thanks!
  16. absolve2525
    2,107
    Finally got some time to work on the 2040. Good call! D912 is bad. I ordered a pack of suggested BAV21 for replacements. I've read resistors before, but I'm trying to figure out how to read diode values. I understand the polarity, but I'll have to read up on the colors. Thanks guys, I'll keep you updated!!
  17. jbailey930
    jbailey930 AK Member Subscriber
    864
    N. Va
    good luck. it is a great receiver. I know since I have two :banana: although one needs a bit of work too. I have schematics but they are large, so i could take a pic as needed. Post an update....
  18. avionic
    45,489
    Fort Dodge, Iowa
    D912 1S1885 (green and violet band) 100v 1 amp switching diode( datasheets on datasheetarchive.com) The BAV21 is 200v 1 amp.
    https://www.mouser.com/datasheet/2/916/BAV20-1320135.pdf
  19. absolve2525
    2,107
    Oooo okay. Is BAV21 too high of voltage? I can order BAV 20 if that's what I need.
  20. avionic
    45,489
    Fort Dodge, Iowa
    Why would I have suggested BAV21 if I didn't think it was suitable ?
    Bill Ferris likes this.
