CR-2040 pop when turned off ONLY, not on turn on.
Discussion in 'Yamaha' started by mr_light, Jan 8, 2013.
  1. mr_light
    mr_light AK Subscriber Subscriber
    370
    Silver Spring, MD
    I have a CR-2040 that pops when turned off ONLY, not on turn on. Otherwise works perfectly.
    I started this discussion in another existing thread with somewhat similar symptoms, but it's just causing confusion there so I have created my own thread to try to separate the discussions.
    Things I have checked/adjusted:
    Speaker protection relay delays for 3-4 seconds and then clicks (connecting the speakers)
    +60 volt pin on one of the power amps and adjusted to 60 volts +/-1mV
    Adjusted idle current to 10mV +/-1mV
    Adjusted DC offset to 0 volts +/-1mV
    Cleaned and lubed all pots (doubt that is related)
    Inspected components looking for leaking/bulging caps or anything else obvious...
    What else should I check?
  2. avionic
    45,611
    Fort Dodge, Iowa
    Both speakers pop?
  3. mr_light
    370
    Silver Spring, MD
    It has blown two sets of 1 amp fuses on both of my "good" test speakers. Apparently the pop exceeds 1 amp every time on both channels. I now only have junk speakers attached.
    I should mention I have a fully functional CR-2040 I can test for comparison purposes.
  4. avionic
    45,611
    Fort Dodge, Iowa
    :scratch2:..Might have a real close look at that relay...ie burnt/welded contacts...Is there a arc arrestor across the power switch?Should be..:scratch2:
  5. mr_light
    370
    Silver Spring, MD
    How to open relay to examine? Also might a speaker relay from a CR-840 work as a substitute (I have a couple of CR-840 donors). There is a spark arrester on the power switch (do they go bad?).
  6. 4seatPilot
    4seatPilot "Broker"
    2,526
    London, Ontario
    You have 840 parts donors? Hmm. Any chance you'd sell me a part or two?
    Sent from my GT-I9100 using Tapatalk 2
  7. mr_light
    370
    Silver Spring, MD
    Send me a PM with what you need and I'll see what I can do. Never mailed international, but I guess I can figure it out.
  8. mr_light
    370
    Silver Spring, MD
    Since the relay is open at turn on for the first few seconds I assume the contacts can't be stuck closed. I'm not sure how the timeing for when they open at shutdown is determined and how this protects the speakers. I did confirm that I have a spare identical relay from the CR-840 that I could swap in if needed.
  9. formuladale
    formuladale Active Member
    140
    The shores of lake erie
    I had the same problem. Shut down it would make a poping sound from both speakers. But on start up relay would click in after maybe 7 seconds and receiver would come on. This went on for approx 6 months. Now as soon as I put receiver on receiver comes on with no delay appears relay has stuck in the closed position. I was told not to use it untill repairs are made otherwise further damage can happen. I hope this helps Regards Dale
  10. avionic
    45,611
    Fort Dodge, Iowa
    Does it POP with the coupler switch (rear panel) in the decoupled or seperated position?
  11. 4seatPilot
    4seatPilot "Broker"
    2,526
    London, Ontario
    Cool... Well do. I have Michigan addresses for easier shipping...
    thanks!
  12. mr_light
    370
    Silver Spring, MD
    I think only the CR-XX20 series had the decoupler switch. I wish this one had it.
  13. mr_light
    370
    Silver Spring, MD
    I can hook up the PRE-Out jacks to another power amp and see if there is a pop if that would serve the same purpose.
  14. asdf_x2
    asdf_x2 Active Member
    169
    Finland
    Also CR-800 has it.
  15. mr_light
    370
    Silver Spring, MD
    I hooked up a separate amp to the Pre-Out jacks and I get the Pop through the external amp. Sounds like it isn't in the power amp section...
  16. avionic
    45,611
    Fort Dodge, Iowa
    Does the loudness and filter switches enhance the "pop"..
  17. Dr. Ear
    Dr. Ear Well-Known Member
    747
    Austria
    A defective spark killer cap (the one soldered to the power switch) could also cause this.
  18. mr_light
    370
    Silver Spring, MD
    I would like to try a replacement spark killer Cap-Resistor. The schematic shows the specs as .033 Capacitor, 120 Ohm Resistor 125vac. Any idea for a source?
    Would this work? "C5: OKAYA 0.2uF 120 Ohm 250V CAPACITORS-SPARK QUENCHERS"
  19. avionic
    45,611
    Fort Dodge, Iowa
  20. avionic
    45,611
    Fort Dodge, Iowa
    Should do fine..
