    Dismiss Notice
CR-420 right channel issues
Discussion in 'Yamaha' started by JPromo, Dec 31, 2017.
  1. JPromo
    JPromo New Member
    18
    I love my 1020, so I picked this up recently for a second receiver. Fully tested upon getting home and the right channel only output distortion, not even distorted music, just buzzes to the beat.
    Thorough de-oxit didn't fix it. Needs caps, but I wouldn't think caps would cause that dramatic of a distortion.
    Output transistors tested no shorts. Then I was checking voltages on the OTs and.. slipped, shorting one left channel momentarily. Suddenly both channels came in clear. It played perfectly for maybe 10 minutes, then quickly degraded back to where it was with the right channel distorted.
    So, what could this be? I'm familiar with the grounding issues on these CRs, so I will start there, but any other thoughts? Thanks!
  2. avionic
    44,597
    Fort Dodge, Iowa
    Possibly cold solder connection somewhere on that amplifier assembly.
    PS get yourself some mini-grabber test leads. To minimize test point slippage and burnt up components.
  3. avionic
    44,597
    Fort Dodge, Iowa
    Tap on the protect relay and listen for audible changes to the effected channels.
  4. JPromo
    JPromo New Member
    18
    Amen. I just get excited when I get a chance to tinker on something.
    On the other hand, the fact that it jolted itself into working temporary eliminates some possibilities.. I will check for cold solder when I get under the board.
  5. JPromo
    JPromo New Member
    18
    I just fired it up and it's good again. Tapping on the relay did not cut it out. I will rap it again when the issue returns.
  6. JPromo
    JPromo New Member
    18
    Next time the channel cut out, I knocked the relay a few times and my right channel came back. Any special way to clean it? The lid looks like it can be popped off.
    Thanks for the suggestion, avionic!
  7. avionic
    44,597
    Fort Dodge, Iowa
    Replacement is prefered remedy.
  8. avionic
    44,597
    Fort Dodge, Iowa
  9. JPromo
    JPromo New Member
    18
    Fujitsu FRL-264 d024/02ck
    Seems that's 24v. Would your linked relay be suitable, or would it be best to track down an NOS one? I'm already putting a mouser order together, so that would be great if it would work. The footprint looks right. Thanks again for the help.
  10. avionic
    44,597
    Fort Dodge, Iowa
  11. avionic
    44,597
    Fort Dodge, Iowa
    No..
  12. Chaulk61
    Chaulk61 New Member
    17
    I have the same issue on my 420.....channels cut in and out when tapping on the relay. However, on mine , it does the same thing when using headphones. Does this rule out the relay as the problem?
  13. avionic
    44,597
    Fort Dodge, Iowa
    Nope...
  14. avionic
    44,597
    Fort Dodge, Iowa
    Look at the schematic. You will see that the headphones and speakers binding posts are both after the relay.
  15. Electone
    Electone Well-Known Member
    756
    London, Ontario, Canada
    Replacement is always the best solution, but if you need a temporary fix, soak some thick paper in Deoxit and drag it through the contacts of the relay. You'll be surprised how much gunk comes off. The problem is that the contacts become pitted and dirty after time. The dirt can be cleaned, but the pits need to be sanded down - better to replace at that point.
  16. avionic
    44,597
    Fort Dodge, Iowa
    Theres always the remote chance of a bad solder connection on the relay or in close proximity to the relay.
  17. avionic
    44,597
    Fort Dodge, Iowa
    carbon
  18. Chaulk61
    Chaulk61 New Member
    17
    Thanks avionic and electone......a new relay is on its way.
  19. Chaulk61
    Chaulk61 New Member
    17
    New relay arrived......soldered it in.....I am currently listening to two clear channels....woo hoo ! Thanks again for the help on my first repair
    avionic likes this.
  20. avionic
    44,597
    Fort Dodge, Iowa
    Excellent!
    Dropped right in. Didn't it.:thumbsup:
