CR-620 sometimes coming out of protection to early causing speaker thump
Discussion in 'Yamaha' started by Eastham, Apr 14, 2018.
  1. Eastham
    Eastham More Class-A than ever!
    2,273
    North West UK
    So my 620 has now started coming out of protection to early causing a negative spike at the speaker terminals, it happens from a cold start after it's been off for a while or if I turn the receiver off then back on after a second.
    When it comes out of protection normally it takes around 3.5s for the relay to close when it opens to early it takes around a second to 1.5s to close.
    Voltages at TR809 are as follows:
    Base: 21v while relay is open, 12.5v after the relay closes
    Collector: 0v while relay is open, 13.22 after the relay closes
    Emitter: 21.5v while relay is open, 13.28v after the relay closes
    Any ideas what I should check?
  2. avionic
    45,470
    Fort Dodge, Iowa
    Reflow the solder connections for TR808 and 809. If that doesn't help replace them.
  3. avionic
    45,470
    Fort Dodge, Iowa
    Let me try to get this right. You turn on the unit. It normally takes 3.5s for the relay to click? When it acts up it clicks at about 1.5s.? There should be no delay at power down , It should instantly open the contacts at power off.
  4. Eastham
    2,273
    North West UK
    Yep and instant off.
  5. Eastham
    2,273
    North West UK
    I replaced TR808 with a KSC1845 and the flyback diode for the relay with a 1N4001 to no avail. I've ordered a KSP2907ATA to replace TR809 which is a 2SB544. I also went around the power supply, amp and protection circuits touching up all the solder joints again for good measure.
  6. avionic
    45,470
    Fort Dodge, Iowa
    Have a close look at C815 and 816 as well. Especially C816 small violet colored 33µf/16v. These are quite often -- bad --.
  7. avionic
    45,470
    Fort Dodge, Iowa
    I have never in 40 yrs found a bad relay flyback diode.
  8. Eastham
    2,273
    North West UK
    I gave this receiver a full re-cap about 2ish years ago, I used Panasonic FC type capacitors.
    I think I'll probably end up re installing the original flyback diode, it's probably better suited for the job.
    Things that may be worth noting, I did change the original filter caps out for higher value 10,000µF Vishay caps, I've also replaced the protection relay with a Omron MY2N 12DC(S) as the contacts on the original relay where fubar despite this unit looking like it'd never been used but the problem was there beforehand, I was hoping replacing they relay would stop the thump.
  9. avionic
    45,470
    Fort Dodge, Iowa
    Good to know..Well lets hope the relay driver TR809 does the trick.
  10. Eastham
    2,273
    North West UK
    I think I may have found the issue... I think If my guessing is correct, I've replaced C815 with a 47µF instead of a 4.7... Is C815 located directly below TR807 by any chance?
  11. Eastham
    2,273
    North West UK
    I'm such a tool, looks like it was the problem after all... I'm gonna let the receiver sit for a half hour and see if it thumps when I turn it on but so far everything seems gravy... I think I need to get my eyes checked... Thanks Avionic!
  12. avionic
    45,470
    Fort Dodge, Iowa
    Little cap closest to TR807 is 4.7µf/35v verified on a parts unit I have here.
  13. Eastham
    2,273
    North West UK
    Yep, I put the wrong cap in when I re-capped it. Wonder why I never noticed the thump before, everything seems fine now. Relay always takes over 3 seconds to click and no more thump.
  14. avionic
    45,470
    Fort Dodge, Iowa
    Great discovery..Alls well , that ends well.
    OMGCat! likes this.
  15. Eastham
    2,273
    North West UK
    Indeed, thanks again for the help. Another problem in my CR-620 that was my own doing... Now fixed!
