Is this white plastic part that fits around the selector shaft on my CR-640 broken? As you can see, it's the same on both shafts. If yes, is it fixable? Or is it okay as it is?
I tried putting a little pressure on them with some needle nose pliers to see if they would squeeze back together, but they didn't really move at all. I don't know if I could even super glue them together if I wanted to. I'd probably have to replace the whole thing if I need to do.
Those nylon pieces are just for the stops. To prevent you from tuning the shaft beyond there limit and possibly damaging the switch. 99% of the time they all look like yours, cracked.
