wa27
New Member
I've got a CR-640 and the tuning meter hardly moves at all. I've read that the deflection on these is always lower than you'd expect, but there is obviously something wrong with mine. It deflects about 1 mm either way.
I can tell it's working to some extent, because I can still use it to "dial in" a station if I use a magnifying glass. The voltages going into it are +- 80mV, but I can't find out what they should be. Maybe it's just too low of voltage? I did notice the Signal Strength meter (which is working) has higher voltage going through it. Is there a way to adjust the voltage to each meter?
I tried reading the service manual, but it wasn't very clear. It looks like I can adjust the discriminator to adjust the center point (which I need to do also), but I don't see anything that adjusts sensitivity/deflection amount. Anyone have any experience with this issue? I assume it would apply to the CR-1040 and other CR-XX40 models.
