CR-800 preamp cap mod
Discussion in 'Yamaha' started by sssboa, Feb 12, 2018.
  1. sssboa
    sssboa Well-Known Member
    796
    I have 2 units of CR-800. I noticed a difference in preamp. In one there is a striped film cap (pic1) instead of ceramic (pic2). Someone's mod I guess.
    Can anyone read the stripe code on that film?
    I cannot find that cap on schematics to read the value, it's c531.
  2. Katalyst
    Katalyst AK Subscriber Subscriber
    826
    Indianapolis, Indiana
  3. Katalyst
    826
  4. Katalyst
    826
    What is the difference between the two?
  5. sssboa
    796
    so seems to be 0.1uF, still can't find it on the schematics.
  6. mbz
    mbz Super Member
    2,447
    Melbourne, Victoria
    Looks like the cap between R541 and R545 on the schematic.
    C529 and C533 are in the neighbourhood. The artwork shows it's
    connected to FR651 and FR502, so it goes from rail to ground,
    so just a high freq/RF noise path
    sssboa likes this.
  7. sssboa
    796
    Yeah, deduction.
    I will replace this cap cause it's cracked, I painted it with silicon. Hope 0.1uF value is ok. It is a mod, isn't it? It should be ceramic disk rather. I don't want to pull the ceramic from my other unit just to check the value, cannot see it from the other side without dismantling tone board.
  8. mbz
    mbz Super Member
    2,447
    Melbourne, Victoria
    I'd go with a 0.1uf ceramic. The CR1000 has a 0.1uf cap (C499) in this position. It is just a noise path so ceramic is fine.
    sssboa likes this.
  9. sssboa
    796
    I ordered 0.1uF film already, should be ok.
  10. rcs16
    4,260
    Baldwin, Ontario, Canada
    I do not know why you want to change those film/disk caps, they will probably out last you.
    Did you change C502?) in left pic that I see (1uF/?) orange and yellow. better to replace with a 1uF film in a 5mm lead space, really does not matter the brand, just 1uF, 50+ DCV
  11. sssboa
    796
    I replace them films if they are damaged.
    I replaced the orange tantalum 1uf/25v with yellow 1uf/50v tantalum Kemet. There are loads of tantalum caps in these old Yamahas.
