CR420/CR66ll Lights
Discussion in 'Yamaha' started by Fhamre, Aug 29, 2017.
  1. Fhamre
    Fhamre AK Subscriber Subscriber
    Picked up a nice little CR66ll. Needed a little attention.
    Looking at some great older posts I repaired a very stiff tuning shaft. Replaced the lights with LEDs.
    I found the DC offset to be about -95mv /channel.
    So I put a 1k trimmer in place of R407 and R408.That allowed me to get to 0mv easily.
    So while I was patting myself on the back I noticed that I no longer had my lights. Was a bit of work to do a nice job putting them in. But I have since taken them out and checked each one,again. No luck.
    I am getting 39V at L1,L2,L4. 6V at L3.
    Any suggestions?
  2. Roboturner91
    Roboturner91 AK Subscriber Subscriber
    1,150
    SW Indiana
    This probably isn't the technical response you are looking for, but I don't have that expertise...
    However I do remember somebody here telling me when I had my CR-420, that the lighting circuit was really sensitive to tapping around in there and bulbs would blow out for no apparent reason. I believed it after going in to tighten up the tuning string and suddenly all the lights were dead. I put new bulbs in and it was fine after that, but I was dealing with regular incandescent bulbs and not LEDs.
  3. avionic
    45,611
    Fort Dodge, Iowa
    Did you check F503 ?
  4. Fhamre
    Yes !
  5. avionic
    45,611
    Fort Dodge, Iowa
    What kind of voltage are you seeing from L1 to L4 ?
  6. avionic
    45,611
    Fort Dodge, Iowa
    Wired in series. If one goes they all go.
  7. Fhamre
    We talking DC or AC? 2.5VAC, 0V DC
  8. Fhamre
    Yes I am aware they are in series. Thx. Strange that the three LEDs worked fine until it seems I addressed the DC offset. Although that could be just a coincidence.
  9. avionic
    45,611
    Fort Dodge, Iowa
    I would have been looking for a DC voltage there.
  10. avionic
    45,611
    Fort Dodge, Iowa
    I think I see whats going on. To get your DC offset under control.Your probably going to have to replace the long tailed pairs.(Diff pair) TR403/405 or TR404/406 with Hfe matched transistors. Any who, the trimmers are loading down the regulated power supply.
  11. avionic
    45,611
    Fort Dodge, Iowa
    Or you have a power supply issue.:idea:
  12. avionic
    45,611
    Fort Dodge, Iowa
    Have you recapped the power supply circuit yet ?
  13. avionic
    45,611
    Fort Dodge, Iowa
    Check R501 180Ω 5 watt'er. So says the schematic.
  14. avionic
    45,611
    Fort Dodge, Iowa
    I would have been expecting around 35-36 volts DC.
  15. Fhamre
    The unit has been performing fine. It was a freebie that I plan to pass on to my daughters room mate whom expressed interest in a vintage piece. The gist, I wasn't planning to recap it if I didn't need to.
    What would be good subs for those transistors?
    Maybe I could try increasing the DC offset to say 35mv or so.
  16. avionic
    45,611
    Fort Dodge, Iowa
    Did you use individual dropping resistors with your LED's ? What Ω value and wattage ?
  17. avionic
    45,611
    Fort Dodge, Iowa
    See what happens.
  18. avionic
    45,611
    Fort Dodge, Iowa
    Each LED would be required to drop 11 - 12 vdc.
  19. Fhamre
    The 180 ohm tests fine!
  20. avionic
    45,611
    Fort Dodge, Iowa
    Damn I was hoping that was it.
