Crap! I need help with my Sub!
Discussion in 'General Audio Discussion' started by H2operator, Nov 10, 2018.
  1. H2operator
    H2operator AK Subscriber Subscriber
    43
    Bryson City NC
    Any help would be greatly appreciated! I brought home my new to me vintage Audio Pro B1-45 and pulled the amp section off to check the foam roll condition, the foam had been replaced but as I was taking the amp off the speaker wires popped off. There is a post marked speaker positive but there are two others. There is continuity between the the other two to ground.
    Any thoughts?
  2. petehall347
    28,257
    uk.. the middle bit
    other 2 appear to be connected together .
    H2operator likes this.
  3. H2operator
    43
    Bryson City NC
    Yes they are connected by my continuity test. I’m probably overthinking this because I’m a novice!
  4. H2operator
    43
    Bryson City NC
    Thanks for the reply Pete!
  5. cademan
    cademan Addicted Member
    9,058
    The other two are both ground. If you were to turn the circuit board over, you would see that they are both soldered to the same ground connections. Use the positive and either negative. Your choice.
