Crazy good-sounding ceramic cartridge
Discussion in 'Turntables' started by needlestein, Feb 13, 2017.
  1. needlestein
    needlestein AK Subscriber Subscriber
    7,140
    West Hartford, CT
    Well, I had to try it just for fun. A Sontone 9TA HC appeared on eBay basically for free, so I jumped on it. I'd heard that it represents the height of the Sonotone line.
    I don't have any special fancy way to hook it up. I just stuck it in a headshell, set tracking force to 2.5g and turned the gain on my Bellari Rolls VP129 way down.
    In a word: impressive!
    I don't think that most people in a double blind test would ever guess that this is not a moving magnet cartridge and an excellent one at that. Room-filling, full, rich sound, better than acceptable tracking, great bass without being boomy, minimal distortion, I could go on.
    Most impressively, cymbals have a sharp metallic edge to the sound, right at the strike, that I only really know from having been a drummer myself in a former life. Maybe this is what the hubbub about transients with ceramics is about.
    This is definitely High Fidelity.
    Looks like a little gold boat.
    slimecity and asilker like this.
  2. NoTransistors
    NoTransistors Dual Turntables Super-Restorer Subscriber
    4,898
    Brooklyn
    I seem to recall that ceramic cartridges, because of the way they work, require No RIAA equalization. Your Bellari unit is a preamp with equalization, so it is most certainly altering the signal, perhaps emphasizing the brass.
    RickB and janikphoto like this.
  3. needlestein
    7,140
    West Hartford, CT
    Maybe, but it sounds great! I'm not that familiar with the Bellari's circuit, but if the reducing gain actually increases resistance, it could be that the Bellari actually sort of acts like a Cer-Mag adaptor. As for the RIAA equalization, whatever it emphasizes, it's not a problem. The sound out of this thing is kind of incredible, but the bass doesn't sound heavy or overdone at all.
  4. NoTransistors
    4,898
    Brooklyn
    I am beginning to miss my BSR mini-changer with genuine diamond stylus.
    Actually, whatever makes you happy is all that matters.
  5. Doug G.
    Doug G. Addicted Member
    7,209
    Rochester, Minnesota
    I remember hearing some relatively expensive consoles, back in the day, that sounded marvelous; dynamic and realistic. I am sure those had ceramic cartridges in the tonearms. One was a late fifties Magnavox monaural console my friend's parents had and our Beatles 45s sounded fantastic on it.
    Another was a higher end mid sixties Sears unit another friend's parents had and we listened to Zeppelin on it and were blown away. It was all there.
    Doug
    cdk99 and bonzo4ever! like this.
  6. NoTransistors
    4,898
    Brooklyn
    I remember, clear as day, my high school chorus teacher playing 'Something' on the school phonograph. 'Till this day, I have never heard it played back with such a powerful, dynamic presence. Like yesterday, but was 1974.
  7. Doug G.
    7,209
    I have a similar story but it was our Junior High School system in the music class room. A Heathkit AA-21 amp with a matching tuner (I can't remember the model) and speakers mounted in the wall. My seventh grade teacher let us bring our 45s to school and play them. To this day, I still feel privileged to have been able to hear those records on such a good sounding system. I can still hear JoAnn Shatek singing along to "Get Off Of My Cloud".
    Oops, I guess this is off topic because I'm sure the cartridge in that system was NOT a ceramic. :D
    Doug
    rshep, bonzo4ever! and Moby Dick like this.
  8. mhainz
    mhainz Well-Known Member
    629
    Melbourne, Australia
    With the higher output and no RIAA equalisation, would it mean you could plug the TT straight into a line input or tape input?
    Pardon my ignorance here...
  9. NoTransistors
    4,898
    Brooklyn
    That is what I was taught.
  10. needlestein
    7,140
    West Hartford, CT
    Theoretically, I could. But my amp doesn't like it. Sounds terrible.
  11. Beobloke
    Beobloke Super Member
    1,682
    South UK
    Not quite. The levels may be right but a ceramic cartridge needs to see a load of 1-2MOhm and a line level input generally only gives the standard 47kOhm.
    Interestingly, some ceramics 'behave' like an MM when loaded with 47kOhm but equally behave like a ceramic when loaded with 1-2MOhm. The Decca Deram is one that springs to mind which works quite well into an MM input, albeit with a fair bit of microphony!
    If you want to hear an old ceramic at its best, one of the easiest ways is to find an old amplifier with a ceramic input. You can then take the tape record output of this amplifier and feed it into one of your regular amp/preamp's line level inputs if you want to keep the rest of the replay chain the same.
    tcdriver likes this.
  12. tubewade
    tubewade Super Member
    1,993
    Outskirts of Oklahoma City
    A ceramic cartridge is, in a way, like a variable capacitance, although it generates a voltage. The impedance is high at low frequencies and lower at high frequencies. The equivalent capacitance is probably something on the order of 1000pF. Using these into 47k inputs, phono or modern aux., will pull their output down some by loading, but also changes their characteristic from constant amplitude to constant velocity, like a magnetic. The most likely problem using a ceramic into a magnetic input is gross overload, but if its output isn't too high or you can adjust the gain then it may work fine. Loading the cartridge at 1k instead of 47k would get the level pretty close to what is needed for a magnetic input. To use a ceramic into a line level/auxiliary input the input impedance needs to be at least 1M ohm to prevent loading or changing of the characteristic.
    The Sonotone 9TA may be the best sounding ceramic ever, but they aren't that easy for most people to source nowadays, but Joseph has a good luck cloud following him around, it seems. The little ceramic in the Zenith Micro-Touch changer is also a pretty good sounding ceramic and has low enough output that I've plugged them directly into a magnetic input with good results.
    Wade
  13. ripblade
    ripblade Super Member
    2,675
    Toronto
    Wouldn't this be technically the same as a strain gauge system? These are highly regarded.
    slimecity likes this.
  14. needlestein
    7,140
    West Hartford, CT
    I'm not sure. Strain gauge needs some kind of bias voltage to generate current. But I don't know if that's an advance on the ceramic idea or a different animal.
    I'll get one of those Panasonoc set-ups one day.
  15. needlestein
    7,140
    West Hartford, CT
    @tubewade I think you're 100% correct. I thought I was hearing mistracking, but after reading your post about overload, I turned the gain on my preamp down so low that I have to turn the volume up on my amp all the way to get a nice listening level and all the sibilance and very mild breaking up sounds I heard at loud vocal passages disappeared totally.
    I'm going to work on one of those circuits in the Sonotone manual and see how that works.
    But what I'm hearing sounds so unbelievably good that I'm pursuing this. It's effing amazing.
    I've heard a lot of people say "sounds like the musicians are right in the room with you." Well, I've never quite had that. Maybe because I'm a musician myself. So I'm not really sure. But the way this ceramic does transients, there is a new level of dynamics that makes moving magnet cartridges (and I have a few of them) and even moving coil cartridges sound flat
    Shure made huge deal out of tracking and that was a huge contribution, but there are I times when I listen to this cartridge that I feel gypped that ceramic technology came to a halt. What another fifty years of technological progress and development could have done boggles the mind. I'm just left with a feeling of loss.
    I gotta get a Micro-Acoustics MA 2002e.
    Also, you want to talk about zero surface noise and incredible blackness? I haven't heard a magnetic type in my system that even approaches this.
    Hi Fi Goodness!!!
    asilker likes this.
  16. onwardjames
    15,426
    Kentucky
    Hey Needlestein, I FOUND a pile of these 9TA HC's in the trash awhile back. 2 spare needles and two carts with new needle. All appear unused.
    Never hooked them up, guess I'll have to give a whirl.
    P.S. These were the unsung finds during that big score I made 2 years ago. Scored a Shure M3, a Shure M7N21D, and that Empire 888-TE. All sitting in a tackle box in the trash by the family of my dead neighbor. They said "You missed all the equipment".
    Jesus wept, what probably got tossed...
  17. ripblade
    2,675
    Toronto
    Some guys are just born lucky....
  18. onwardjames
    15,426
    Kentucky
  19. onwardjames
    15,426
    Kentucky
    Phew. That was a bitch. Had to use brass spacers to get the cart away from the headshell, which was dragging, and for VTA. Also, the extra weight helped, as this is a light cart, and my counterweight was full forward.
    After getting the Stevenson alignment, and dropping on my first track, John McLaughlin "Electric Guitarist", I have to say, I'm VERY impressed.
    Natural sounding. Pleasant. Vinyl as I remember from my youth.
    And I've had these here for years, lol.
    wualta and tubewade like this.
  20. onwardjames
    15,426
    Kentucky
    Just swapped the stylus on the mounted cart, as it was listing towards the spindle too much for my liking, with the brand new stylus.
    Wow. Things just got better. I'm listening on my mixing speakers (Alesis, and unkind as hell) and the sound is pretty splendid.
    Will this displace my beloved Stanton 720ee? Don't know yet. But this has been fun (except mounting that bitch. That sucked.)
    P.S. - Needlestein, are you noticing that this cart IS LOUD WITH ZERO AMPLIFICATION? What I mean is that just the needle dragging thru the grooves, you can very easily hear the music, even with the lid down. Wow.
    Audioraven likes this.
