Crossover, no capacitors?
Discussion in 'Speakers' started by paultlaw, Oct 11, 2017.
  1. paultlaw
    paultlaw Active Member
    258
    Hi all, quick question, do some crossovers not use capacitors? Just inductors and resistors??
    Opened up mission freedoms 752, no sign of any capacitors I could see anyway.
  2. StimpyWan
    3,039
    Blue Ridge Mountains!
    Is this the crossover?
    There looks to be at least a 15mdf blue capacitor. Plus, the yellow rectangular part, wired with 1 ohm resistor, is probably a cap too. I just can't make out a value from this angle.
  3. paultlaw
    258
    Maybe it's a polyester cap I was looking at, I'll grab a picture, should clarify things.
  4. paultlaw
    258
  5. whoaru99
    whoaru99 Epic Member
    39,770
    LoTL
    The white box with yellow filling is a capacitor. Most likely a film capacitor.
    jwrauch likes this.
  6. paultlaw
    258
    Hmm what does the 475k mean then? I though all caps came in a uf value or a pf value?
  7. whoaru99
    39,770
    LoTL
    4.7uf, 10%
    jobrewer1983 and darkblue94 like this.
  8. paultlaw
    258
    Thank you kindly, worth changing or "upgrading"?
  9. whoaru99
    39,770
    LoTL
    Being most likely a film cap it is unlikely to need replacing. Changing it for other reasons is up to you.
  10. kirk57
    kirk57 Some guy on the Internet Subscriber
    6,019
    Chicago's North Shore
    But to answer the original question, yes, some crossovers (such as the ones in my speakers) do not employ capacitors.
    And no, I'm not really using Panasonic Thrusters.
    Retrovert likes this.
  11. paultlaw
    258
    Thanks for the help. I'm on the fence then about changing them. For a set of castle speakers I have, I went and ordered a bunch of solen caps. But they are all replacements for electrolytic caps. So the need might actually be there for those.What are your personal feelings/opinions on whether or not you would change the caps in the mission speakers?
  12. paultlaw
    258
  13. nfafan
    nfafan Well-Known Member
    501
    East Coast
    I have a pair of E-V 12TRXBs that had nothing in place as crossovers - nothing, zip, zilch, nada. All was running full range. I finally added a single cap in front of the tweeter and they sound even better now.
  14. toxcrusadr
    29,526
    Central Missouri
    I'd probably leave that cap there unless there is something off about the sound. I assume you don't have test eqpt. or you would have checked the cap. Without some evidence to the contrary I'd probably not feel compelled to replace it. BUT...
    If you really like the speakers and want to find out if they can sound even better, and if they are a few years old, it won't cost more than $5-$10 apiece to replace that cap in both speakers with something pretty good. I recapped my 1991 Klipsches which had two film caps each and they did sound better.
  15. paultlaw
    258
    OK last night I recapped one of the crossovers, and did a comparison between the speakers, and quite honestly I could hear absolutely no difference whatsoever.
    Bit disappointed given the money spent etc
  16. botrytis
    Sometimes that happens. It is a learning curve - now you know - film caps (don't replace).
  17. paultlaw
    258
    Apologies, I actually replaced electrolytics in one of my castle speakers, wrong thread! So the film caps made no difference in those, even though they replace old electrolytics
  18. stickman
    stickman Super Member
    1,468
    Los Angeles
    The only cross-over capacitors that ever need replacement are those that have faded out of the specified operating parameters or suffered internal breakdown over time. Inexpensive NP electrolytics are far more likely to fail over time than film capacitors but better quality electrolytics found in older high quality speaker brands can last a long time. The fact there was no significant change in sound quality with the capacitor swap just means the electrolytic capacitors you replaced were still functioning properly. Nothing ventured, nothing gained! (lol)
