Macro-Tech is the touring-grade amp. Earlier models were the familiar "big iron" methodology. The newer ones are switching-type amps.
The CEs were more of a mid-line "bar band" or install type of amp, for lack of a better way to describe them.
Both Macro-Tech and CE have various models/outputs so one cannot rely just on the name as a guide to power. There was also the Micro-Tech line that sometimes people confuse with Macro-Tech.
I'm somewhat familiar with the CE line up having three CE4000s. The CE1000 and CE2000 are conventional "big iron" amps, while the CE4000 is TOTALLY different being a switching power supply and switching output. Rumors are the CE4000 was foundation of I-Tech line, but of course I-Tech is newer yet with DSP and probably enhancements and higher power models.
Based on my "studies" on pro sound forums, the CE1000 and CE2000 are not too well regarded for reliability, but given the context of professional/semi-professional use, that may not have a ton of significance for home use. However, the CE4000 seems to have a pretty loyal following for sub amp duty if you don't mind older amps and don't need all the DSP stuff built in.
Myself, I do not use the CE4000 for mid/high instead using some QSCs there, but do find the CE4000 makes a pretty good sub amp. The CE4000 has universal power supply and power factor correction built in so it's sort of like a regulated power supply. It will produce virtually rated output down to about 95 or 96 volts input which is nice if you have crappy mains supply. If you happen to have 200-240V available, there is no switching required, just plug it in, and output capability increases from 2,800W (4 ohms bridged) to 3,600W.
