And they don't overload in RF fields either.
I have both a FM1 and a FM2.
Both of these have a overload issue, under the same conditions, the tuner in a Sansui G-7500 (which is not a top end tuner) does not overload the same. I think it is because of the jfet mixer design that Crown used, in both FM1 and FM2, they have the same 2n5485 single jfet type of mixer. I do not think they designed it very well as far as IM performance goes. The G-7500 uses a bjt mixer and have better overload margins.
Both the FM1 & 2 are sensitive and fairly selective, no more than the tuner in the G-7500 however. FM1,2 have almost the same IF filter chain using the old LM703 IF amp, except the ceramic filters are a bit different and the FM1 uses a SAW as the last filter element.
What I would have liked Crown to do is to add a narrow filter option for some congested as as other higher end tuners have done.
As far as the pulse count detector in the FM2, I do not notice that it offers any performance increase over the older FM1 std quad detector using a CA3189E.
The FM1 blew its controller, so that is how I got it so cheap at $50. for years I could not find a GI controller
To get the tuner working, I wired it up to a heli muti-turn pot to the varactor diode supply and added a center tune meter so that I could use it and test it out. Recently I found that Littlediode is selling the GI controller for the FM1 (AY3-8115P), so I ordered one and it is in the mail. Hopefully I can get it back working again with a controller.
