I owned a C-28 and though I complained about its issues, when working was a rather sweet unit. If you want a warm smooth phono stage the C-28 is a winner. Where a C-29 is a touch quieter, more revealing, with tight bass, and works well with percussive instruments, a C-28 will make you think you are at an actual concert with a lot of recordings. Command recordings always sounded great if you can get your head to forgive some of the ping pong effects. C-28 also calmed some of Phase 4 London recordings that could be edgy. The 28 was an easy pre-amp to listen, too. Friends of mine used 28's with a Hafler D 500 in one case and another was using a 28 with his 7200 for years with Mac speakers . The first used a Grace F9E and was a fantastic analog performer. There isn't V-15 or Stanton that can match the combination. The other gentlemen was using Ortofons with a linear tracking arm and the sound was superb, but could not match the Grace. So a 28 is no slouch and if you have the divider panel on the phono circuit board you will have definite channel separation superiority. A C-28 is sure to please. But you need to have revealing amps and speakers to allow the pre-amp to show thru. Any clouding will really handicap a C-28. C-28's like cartridges with a lot out output. Certain Ortofons with step up transformers could make C-28's shine, a MC 30 for instance. With a Sl 15 Mk II the response was flat to beyond 30 kHz. The combination with a little 2 db dip from 1600 to 5 kHz as I remember could really help calm Altec, Klipsch, and Ev horn speakers. It even calmed my Concert Grands 209's a bit before I got room Equalizers.
Why did I get a C-29? The mis-tracking volume control, the intermittent low level input circuit connectors, and the alignment issues of the input select shaft that could cause intermittent failure of one channel on some inputs and the other channel on other inputs of the C-28. Getting the alignment right for consistent operation with the long control shaft could be an issue. The trim controls on top of the unit always needed cleaning . In that respect my C-34 is the best preamp I have ever had. Switching is quiet and the variable controls have never been an issue. But like the C-28 the stepped tone controls of the C-22, C-29, 26 and 27 were always noisy.
My former C-28 today is being used with a MQ 104 feeding a MC 2200 pushing a Pair of ML-2C.
