aldena007
Legacy Audio Aficionado
I have a CT-F950 on my bench to work on and I noticed the fluoroscan display appears to have some sort of artifact in the display. The display shows the signal strength with bright segments that I am used to seeing with the other units I have/worked on but there is a dim pulsating signal also showing full scale on the display. This ghost signal is annoying and I need to track down the cause. I plan to completely redo the power supply board with all new capacitors/silicon. Will this clear up the problem or do I need to dig deeper?
