DaaDaa
Set the controls for the heart of the pun
so i like to liten to NPR and the local rock channel and i picked up a yamaha Tuner T-560 which matches my silver EL34 tube amp in appearance and the CA-2010 amp that im trying to restore so i like the wat it looks and it sounds very good too considering that i am using an 8 dollar walmart indoor antenna. I wanted to improve the sound and outdoor or bigger antennas are currently out of the question so i figured maybe a more technologically advanced and just newer tuner would be better and i saw this mint T-70 and bought it. but it sounds worse. it just sounds a little bit fuzzier (background noise) and a little less warm and live compared to the T-560.
I opened it up to try to do the alignment and i noticed two things:
1 - from the slight initial click of the screws when unscrewing to the pristine insides, not a speck of dust, it seems like it has never been opened.
2 - it is missing the fuses!!!!!!
i mean im not even sure why it is working? has it been rewired to not need fuses?
so what do you all think is up with that? should i stick two fuses in there?
