Kingsin7
Hello AK
I recently purchased a custom speaker set that was built by a UC Berkeley engineer back in the 70s. The set features:
15" JBL LE15A woofers (8ohm)
15" JBL PR15 Passives
JBL 075 tweeters (16ohm)
Altec 802D Mids (16ohm)
Altec 811B Horns
The crossovers were made from scratch as were the cabs. There are two large "bass coils" hooked into the XO in each cabinet.
I bought these speakers in the Bay Area where they auditioned great. I unhooked and tested all drivers with my meter, and they all checked out.
I was forced to remove the protruding horns to be able to fit both cabinets into my truck (had the camper shell on), where I put them on their sides facing each other.
I hauled these massive speakers into my garage and hooked them up to find neither of the woofers were functioning. Upon opening the cabs up, I found connections in the custom XO's had come apart in places during transit. The XO's were the only weak link in this setup as they are home made and frankly Mickey Moused, though I admittedly could never have built them myself and commend the engineer that created them. Lots of lamp wire and exposed connections (pictured)...
I re-soldered the connections where needed but the woofers still wouldn't come on. If I cranked the power slightly they would activate in a horrid muffle and I quickly shut the amp off. After some head scratching I noticed they were both virtually frozen stiff when unpowered... There is (very) slight play when manually moving the voice coil in and out by pulling on the cones.
I hooked in another woofer to each speaker and it worked fine.
So, here I am trying to figure if this is an easy fix or if a reconing job is needed. Local quote is about $400 for new cones/foam...
What I really want to know, more than anything, is how they got frozen. Whether this was due to the shock of transporting them the 60 miles to my home (never happened before) or something to do with the XO wiring being disconnected in places when first powered on back at my house...
Any advice will help!
Thanks,
Steve
Altec 811B Horns
Thanks,
Steve
