Hi all!
I have an old Velodyne HGS10 subwoofer. The amp is shot, which seems to be a common problem even after the amp is repaired. I am attempting to make use of it with an external amp and a Minidsp of eq'ing the low end roll off. It has a dual voice coil setup in a push pull configuration. Can I just connect 1 voice coil with + to+ and - to-, and the other + to- and - to +? Or do I need to invert the phase of one of the amp channel signals? Or is that doing the same thing in a different way?
