DAC for Raspberry Pi 2 B+
Discussion in 'DACs' started by Crazyblocks, Oct 4, 2018.
  1. Crazyblocks
    Crazyblocks Active Member
    117
    Richmond VA, USA
    Looking for a dac for the raspberry pi 2b+
    Any recommendations?
  2. telemike
    telemike Super Member
    2,135
    Greensboro, NC
    I use a HiFiBerry DAC
  3. judsonw
    judsonw Well-Known Member
    845
    Bellingham, WA, USA
    HiFiBerry is good. I use the HiFiBerry digi board to an external DAC, but the HiFiBerry DAC is good too.
  4. E-Stat
    7,195
    If you're looking for a HAT, I would recommend the Allo DAC.
    I use an external DAC, but prefer the Allo DigiOne to a previously owned HiFiBerry board.
    judsonw likes this.
  5. Adam2CH
    Adam2CH New Member
    5
    I currently am using this PiFi DAC from China with a Raspberry Pi 3 B+ and Volumio, controlled via Volumio app on Android. It's very similar to the HifiBerry "standard +", whereas the "pro" version has 2 clocks. There are also several more Raspberry Pi DACs located there. Hope that helps.
    cpt_paranoia likes this.
  6. for_p1
    for_p1 Addicted Member
    5,530
    Northern TX
    Almost anything with USB input will work. I used TEAC 501 and Oppo 205 with great results. I used piCorePlayer software along with LMS on a separate server to manage library.
    lico and ldatlof like this.
  7. Tim Murphy
    Tim Murphy New Member
    1
    For Raspberry pi 3B + using Voulmio 2.0 streaming software. The Allo Kali Reclocker with Piano 2.1 DAC. It takes some common sense to configure, but when you have it configured right. The two PCM5142 DAC's can deliver 384 kHz/32bit. With a very impressive SNR of 112dB.
    Using this setup with my Eico ST 70 rebuilt amplifier, playing my hi res vinyl 24bit 96k or 192k files sounds amazing. Cleary detailed and with great stereo
    Separation.
  8. ldatlof
    ldatlof We are all steak Subscriber
    2,914
    Las Vegas
    I am using a HiFime 9018 Optical DAC with my RPi. To use with the RPi It requires a USB to optical converter. I use a S.M.S.L. X-usb Digital Audio Interface for that purpose. Both units are small (like the Pi) and inexpensive. Together they put out very detailed sound.
  9. beanoil
    beanoil That's not how this works
    558
    Godfrey, Illinois USA
  10. cpt_paranoia
    cpt_paranoia Super Member
    1,181
    I've got one. Volumio recognises it as a HiFiBerry DAC+
    Works fine, including hardware volume control.
    I'll leave the subjective reviews to the golden ears types; mine aren't.
    The genuine HiFiBerry DAC+ Pro ought to be better, as it provides the clock, rather than using a clock generated by the Pi. And, at £33, it's not exactly expensive.
