DAC for Raspberry Pi?
Discussion in 'Digital Sources' started by Ziradog, Nov 5, 2017.
  1. Ziradog
    Ziradog AK Subscriber Subscriber
    996
    Apex, North Carolina
    I have a Pi set up with a HiFiBerry DAC+ to stream music in one of our bedrooms. I am going to do a similar set up for the garage. I was wondering if anyone could suggest another low cost DAC to try? I like teh HiFiBerry but I want to take this chance to explore. Thsi being a garage system, I don't want to spend big $. Suggestions?
    Thanks.
  2. for_p1
    for_p1 Addicted Member
    5,469
    NJ
    For garage use, just connect amplifier to stereo output of Pi 3. No need to add any DAC.
  3. Ziradog
    996
    The audio output from the Pi is just slightly worse than a 1970's transistor radio. My standards for the garage are a little better than that. The Pi with the HiFiBerry DAC I have in the one bedroom is pretty decent - at least as good as a basic CD player. It was $30-ish. Thinking something along this line (<$50 - $60), either USB DAC or a "Pi HAT" DAC, just to try something different.
  4. whell
    whell AK Subscriber Subscriber
    3,537
    Livonia, MI
  5. for_p1
    5,469
    NJ
    Get Audioquest Dragonfly then.
  6. 45rpmspinner
    45rpmspinner Active Member
    Allo makes both a slave and master DAC [in several variations] for the PI. I've no experience with their products, but did just order one of their Volt+ T-amps.
    Shipping is a bit high, but still possibly worth a look.
    https://www.allo.com/sparky/miniboss-rpi-zero.html
  7. E-Stat
    E-Stat Super Member
    4,549
    Allo Boss.
    I prefer using the RPi as player only using a digital output to feed my choice of DAC. I began with a HiFiBerry Digi+ and replaced it with the significantly better Allo DigiOne.
  8. mars_volta
    mars_volta Super Member
    2,124
    PHAT DAC
  9. cvt01
    cvt01 New Member
    28
    I use the Topping D30 slightly above your budget but it can decode DSD. I had no luck with the HifiBerry module I purchased. I could not get it to work for some reason - I suspect it was a hardware issue as I tried several Pi player distributions. The Topping connects through USB and my RuneAudio recognizes it and they play along nicely.
  10. Ziradog
    996
    Looks like these require soldering the header, an is meant for Pi Zero?
  11. Ziradog
    996
    Interesting. What makes it better that than other i2S Dacs?
  12. Ziradog
    996
    That's a little pricier than I want to spend for the garage. Maybe for the bedroom.
  13. E-Stat
    E-Stat Super Member
    4,549
    First of all, the DigiOne is not a DAC. It outputs a digital signal over either coax or BNC, the latter of which I use for my Music Hall DAC 25.3.
  14. mars_volta
    2,124
    Correct
  15. ldatlof
    ldatlof We are all steak Subscriber
    2,685
    Las Vegas
    If you are looking for cheap and to use in the garage the Behringer UCA-202 fits the bill at $30 for a new one.
  16. telemike
    telemike AK Subscriber Subscriber
    2,177
    Greensboro, NC
    I like the Hi-Fi Berry DAC+ with the Burr brown chip. Sounds good enough for me.
