DACs with AES/EBU out
Discussion in 'DACs' started by Tdogzthmn, Feb 7, 2018.
  1. Tdogzthmn
    Tdogzthmn Active Member
    237
    Bay Area
    My music setup has been moving away from Hifi components to using more Pro audio gear. My next pair of monitor speakers will likely have AES/EBU inputs but im not very familiar with DACs which have this type of digital output. I'm hoping to hear some someone that is currently using a DAC with this type of digital output.
    Thanks!
  2. JP
    JP 7480 74111110101115
    2,569
    NYC and Brookfield, CT
    It would seem a DAC isn't what you need.
  3. Tdogzthmn
    237
    Bay Area
    AD/DA converters might be a better term?
  4. JP
    2,569
    Your want to go from what to AES?
  5. gvl
    gvl Super Member
    1,084
    Why do you need DAC if you want to send a digital signal to your monitors that apparently have a DAC in them?
    cpt_paranoia likes this.
  6. Tdogzthmn
    237
    Bay Area
    I want something that can take Optical, USB, and RCA and output Balanced XLR and AES/EBU to my monitor speakers.
  7. JP
    2,569
    RCA being analog, or SPDIF?
  8. gvl
    gvl Super Member
    1,084
    Sure, but why send both XLR and AES/EBU to the speakers and why do you need a DAC for the latter ?
  9. Tdogzthmn
    237
    Bay Area
    I would be only using one connection at a time but I'd like both output options to cover a range of suitable monitor speakers.
  10. gvl
    gvl Super Member
    1,084
    You can find a DAC with a SPDIF output (they do exist) and use a SPDIF to AES/EBU converter, even a fancy one with re-clocker like the Mutec MC-3+ if your budget permits, although I don't know why the signal has to be passed through the DAC in this case. Another option is to look into pro studio gear. If you want to control the volume too through the DAC with monitors connected digitally it may be more difficult to do with home use gear but there should be something in the pro-audio world.
  11. mjw21a
    mjw21a Super Member
    3,257
    Brisbane, Australia
    Plenty of DAC's have balanced XLR out, though not AES/EBU out . If the speakers have that it would indicate that they already have an integrated DAC iin which case you can probably use something like a Gustard U12 interface for USB input. You're really looking for an interface rather than a DAC.
    I suspect they more likely just have balanced XLR inputs. If that's the case you could take a look at any number of DAC's on the market.... Pretty much every Gustard DAC has balanced XLR outputs. Make no mistake though, these are analog outputs. The very job of a DAC is to convert digital signals to analog.
    stish likes this.
  12. RichPA
    RichPA Don't drive angry Staff Member Super Mod Subscriber
    Agreed, the speakers probably have analog input on XLR, typical for pro powered monitors, and lots of DACs have XLR outputs. Benchmark comes to mind, but there are many others.
    stish and mjw21a like this.
  13. mjw21a
    mjw21a Super Member
    3,257
    Brisbane, Australia
    Personally I'd be more inclined to look at a Crown XLS1502 amp and run that to unpowered speakers. I've been considering a blend of pro audio and Hi-Fi gear a while myself. I'm curious about a high wattage setup rather than the lowish wattage tube amps I currently run..... I don't expect better, just different.
  14. gvl
    gvl Super Member
    1,084
    However, I think there is something wrong with the idea of using an expensive audiophile/studio grade DAC as a cable coupler.
  15. RichPA
    The OP needs to clarify whether the monitor inputs are digital or analog. You can buy devices that will take an optical, RCA, or AES/EBU digital input and put out an AES/EBU signal. But I've never seen one that will do that with a USB signal, which is fundamentally different.
  16. gvl
    gvl Super Member
    1,084
    Plenty of USB to SPDIF connectors out there, many have the all Toslink, Coax, and AES outputs. Going from to SPDIF to USB is not as common, but Mutec 1.2 can do.
  17. RichPA
  18. mjw21a
    mjw21a Super Member
    3,257
    Brisbane, Australia
  19. BobbyBluz
    BobbyBluz Well-Known Member
    933
    With a bit of looking you can get a nice used Behringer SR2496 that has everything but USB and RCA (easy to make or buy adapters for the XLR's) in the $100 price range (I've bought three of them for under $100 including shipping). How well do they work? Amazingly well. We used them in radio broadcasting and I have one in my studio. There's even a cult that does mods on them from mild to wild. They punch far above their price range. http://silentsky.net/wordpress/archives/404
  20. mjw21a
    mjw21a Super Member
    3,257
    Brisbane, Australia
    Behringer gear does have a bad habit of being noisy though....
