Question - How are the DQ-10 supertweeters supposed to sound? I don't hear very much sound output from either of them and I don't know if this is correct or not. I'd expect more output from them but I'm mostly familiar with three way systems, not 5 way systems such as these.
Background - This weekend I brought home a pair of DQ-10 speakers after auditioning them at the sellers home with my own source material (CD). In the sellers room they sounded nice but once set up at home they immediately sounded a bit dull. After removing the grill frame and rear cage I was able to selectively listen to each driver. There was no output from either tweeter and little output from either supertweeter. All 4 of these drivers worked when tested and the tweeter problem was fixed by replacing both (blown) fuses with appropriate 0.75 Amp fuses.
The speakers sound nice, though I wonder if this can be improved upon. The p/o had the woofers recently refoamed by Regnar. The crossovers have not been updated so I'm contemplating replacing some or all of the capacitors and interested in DIY suggestions.
Thanks,
Steve
Thanks,
Steve
