I am bumping a 12 year old thread to say thank you to AK for coming through for me yet again.
I recently acquired a Realistic STA-860, same model as the OP.
I plugged it in, and hit the power switch. Nothing happened. Zip, zero nada.
Hit the power switch again, unplugged it, and started with the basics. Blown fuse. Violently blown, plating part of the glass inside with metal and blackness.
Break out the DBT time. Put a new fuse in, 5 amp, and screwed the 150watt bulb in to the DBT. Bright bulb immediately. Loud hum from the speakers. Tried the 200watt bulb. Same deal. Figured there was a short, as the original fuse blew for a reason.
Hopped on AK and found this thread.
Bad Bridge Rectifier. Ok, easy enough to check, even with my limited ability. I don't mind working on the bigger parts, harder to mess up. (Usually)
Pulled out the multimeter and loaded it for Ohms. Readings on the BR were as follows, same with either polarity: open, open, open, and 0.6 ohm. Now, I know how a rectifier works, and that was totally unacceptable.
Here is the culprit:
The screw threads in the aluminum heatsink had stripped, maybe due to heating and cooling? That allowed the heatsink to come loose, and probably hastened the death of the rectifier.
Now maybe some of you have these kind of things laying around all over, but I do not. I did however have 4 decent sized diodes and a soldering iron, so I made myself a bridge rectifier. Here it is installed:
Put the receiver back on the DBT with the 150 watt bulb and voila, the bulb flashed orange briefly and the receiver powered up with no hum.
Added a little Deoxit to the balance and volume pots, and this receiver is now restored to working order. My custom rectifier did not even warm up in testing, although I did not really put much volume out of it.
So, thank you AK, what would I do without you? You guys (and gals) are the best.
