JesusGreen
Member
So I recently got a second hand Debut Carbon with a 2M Red. I noticed a couple of things though, I was experiencing some distortion on certain tracks on certain records - and the 2M also didn't seem to handle mid-range quite as well as I'd hoped. I wasn't sure if the distortion was just an old stylus, so I went to switch out the cart to test, and broke off a couple of the pins in the process, rendering the cart dead.
I decided to buy myself a new cartridge, and after going over my options for several days, I settled on the Grado Prestige Black1. So I ordered it, along with a couple of records: Somethin' Else - Cannonball Adderley, and Come Away With Me - Norah Jones.
I gave them a spin, and I quickly noticed something. The Norah Jones album was filled with bad distortion. It's most noticeable on ch, d, and t sounds and less so on regular "s" sounds, but also noticeable there. If you've ever watched a video or been in a call with someone who was way too close to their microphone and talking too loud into it - that's the kind of distortion I'm hearing. (I initially thought it was just this album - but later confirmed that I was experiencing sibilance and IGD with a good amount of my records)
Now I suspect an alignment issue, so I've been trying to get my cartridge aligned. When I first started, I had no idea what I was doing, so I spent a good 15-20 hours completely not understanding alignment whatsoever and getting nowhere with it.
Eventually I found a slightly better explained tutorial that said that you're meant to align the lines on the protractor with the cartridge body, and so began attempting that. So using Baerwald, I did that, but it didn't help, I was still experiencing sibilance and IGD.
I noticed though that with the sides of the cartridge aligned, the cantilever was VERY off, pointing significantly to the right.
So I instead tried to align by the cantilever. It took me a long time, since I have very unsteady hands, and horrible eyesight even with my glasses, but after probably 8-9 hours of going back and forth, I got the cantilever aligned using Baerwald.
The overall sound was better, but I was still plagued by sibilance and IGD. It was then that I began searching up the issue, and discovered several threads where people with my same turntable complained about these issues with the original 2M Red cartridge. The solution they all found to resolve the issue? Using a custom arc protractor rather than Baerwald.
So I downloaded Conrad Hoffman's arc protractor program, and put in the following numbers that I managed to find for my turntable:
Pivot-to-spindle: 200mm
Inner groove radius: 59.4103mm
Outer groove radius: 143.926mm
Which gave me: 18.5mm overhang, null points: 65mm and 119.1mm, and an offset angle of 24.917*
These all seem correct for the Debut Carbon.
Now the instructions with the program say that the first step is to ensure the stylus follows the arc. If the stylus is on the arc at the outer edge, but is short of the arc near the spindle, then you move the cartridge further out - and if its on the arc at the outer edge, but goes over the arc near the spindle, you move the cartridge further in towards the pivot.
So I did that, but then..
Question 1) After getting the stylus to follow the arc, it says to align the cartridge body or cantilever to the lines around the null points. So I try to do that, but as soon as I get the cantilever aligned to both points, it no longer follows the arc precisely all along. Should it? Or is the arc just there to show me roughly how far forward the cartridge needs to be - and then to be disregarded once you work on aligning the cantilever/cartridge body?
Question 2) My cantilever isn't centered, it's angled out slightly. Should I adjust azimuth to take this into account? If I adjust so that the cantilever and its reflection appear straight, then the cartridge is angled to one side quite a bit. If I make the cartridge straight, then the cantilever is off a little (albeit not as much as the cartridge seems to be off when I do the opposite).
Question 3) Is there some trick I'm missing to alignment that allows me to know which screw I need to move forwards/back and by how much? I get that I can slightly rotate the protractor or platter until the cantilever seems straight, and then see whether the cantilever is in front of or behind the point - but I don't get how I'm supposed to know which screw needs moving from that point? I've spent the last 7 hours trying with no luck to get this aligned, and I feel like even for alignment 7 hours is way too long - I must not be understanding something correctly.
Question 4) Should I stick with the numbers I input above? Or should I be using the DIN measurements for inner/outer groove radius even if it gives me a slightly different overhang to my turntable specs?
Thanks
Thanks
