Decided to buy a NP-S2000
Discussion in 'Yamaha' started by dino74, Jun 14, 2018.
  1. dino74
    dino74 AK Subscriber Subscriber
    107
    Oceanside, CA
    I got a bonus at work today and decide to do something potential stupid. I've always liked the look and build of the NP-S2000 but its limited because it doesn't support MusicCast and/or there's no digital coax in.
    But was bored tonite and just read up on its internals. Dual Burr-Brown PCM-1792A DAC. Nice! Read the spec sheet at http://www.ti.com/lit/ds/symlink/pcm1792a.pdf and its a pretty simple interface, spi control/i2s data. Then I came across some hidef photos at https://www.hifishock.org/gallery/electronics/yamaha/source/music-server/ and saw this one. Its the controller card.
    The lower left corner connector goes to the DAC board. I see they list the chip select right and chip select left. these must be the SPI control lines. I'm hoping the other ones are the i2s data lines. So I said what the hell and ordered one of the refurbs from Accessories4Less. I'm going to try to connect a SPDIF to i2s board to those pins and see it I can turn this into a usable DAC. Hope this works!
    Edit: change i2c to i2s
    ivandezande and OnTheBlitz like this.
  2. OnTheBlitz
    OnTheBlitz ->"Throw it again!" Subscriber
    22,365
    -27.125817, -109.276726
    It's a great unit. I have one and love it. Make sure you update the FW to the latest version if it has not already been done. I think it is 3.10? This document says 3.00, but I know they came out with more after that. You'll need to make sure it is accessing the internet. If you can get Internet radio, then follow this guide and it should update you to the latest. 192KHz....
  3. OnTheBlitz
    22,365
    BTW welcome to AK!
    I typically hang out in the: What are you listening now -and more
    Thread
    -Blitz
  4. OnTheBlitz
    22,365
    If you can mode it, which is possible, to have selectable "use as external DAC input" or the "internal 2000 functions", I would do that. This unit does FLACS (and MP3) extremely well. As you can see it is built like at tank. Wait to you go to lift it up! LOL.
  5. dino74
    107
    Oceanside, CA
    It be much harder to keep the existing internal functions. I'm hoping I don't need to de-pop or blue wire any parts, that way I can put the device back to stock mode. All my rooms use MusicCast and its nice that I can link them, so I'd probably use a WXC-50 to this.
    OnTheBlitz likes this.
  6. OnTheBlitz
    22,365
    Cool! I would be very interested in see pics once you have it all worked out.
  7. OnTheBlitz
    22,365
    I have called Yamaha since 2014 for a service manual. They never made one for this. I always get service manuals. Kind of strange, Yamaha is always on top of their manuals and they are all first rate.
    If you some how "magically" come across one, please let me know.
    Thanks.
  8. dino74
    107
    Oceanside, CA
    Will do!
  9. dino74
    107
    Oceanside, CA
    This guy is selling the service manual. https://www.electronicsrepair.net/ I'm reading it right now. I don't feel comfortable giving it away because my info might be embedded in it but $10 was quite reasonable.
  10. dino74
    107
    Oceanside, CA
  11. dino74
    107
    Oceanside, CA
    Got the factory "refurbished" unit from Accessories4Less. Bent RCA connector, missing power cord, and missing remote batteries. Doesn't work either :wtf:
  12. OMGCat!
    3,209
    El Sereno, CA
    That's not so great at all. I didn't think refurbished meant to steal the goodies out of the box and toss the rest down a flight of stairs. Hopefully they'll make good and get you a proper replacement.
  13. dino74
    107
    Oceanside, CA
    It was a bummer but A4L was pretty quick with shipping out another unit with no hassles.
  14. dino74
    107
    Oceanside, CA
    Got the replacement unit. Unforunately, it onlys plays 44Khz 16 Bit flac, 24 Bit files don't play. Going to contact Yamaha support for this one.
  15. dino74
    107
    Oceanside, CA
    In the meantime, I got this Cirrus Logic WM8804 board to translate the spdif to i2s.
  16. dino74
    107
    Oceanside, CA
    Finally got something other than 16 bit / 44khz files to play by leaving the unit off for ~30 minutes then playing it as soon as I power it on.
    Unfortunately it stops playing after a minute.
