Deciding between two entry-level amps
Discussion in 'New Gear - Values' started by David Politi, Jan 3, 2019.
Which amp should I buy?
Poll closed Jan 10, 2019.
  1. Option A Douk Audio EL34
    0 vote(s)
    0.0%
  2. Option B Luxury Aiqin L-02 EL34
    100.0%
  1. David Politi
    David Politi New Member
    9
    Hey AK!
    I'm a new member here, looking forward to making some new friends.
    My current setup:
    • Budget AT-120 turntable (belt, MM)
    • Schiit SS preamp
    • Klipsch RF 61 (98db sensitivity)
    • 20x20' room, no room treatment
    I'm upgrading my hifi at home with a tube amplifier, and I'm looking at two similar models. They appear to be from the same company (Nobsound) and I can't figure out which one to buy. Both are EL34-based SET, around 8W output/chan @8ohms, and around $350. It appears the cost-savings has affected the transformers the most, and both models are hand-wired on scaffolding.
    • Option A Douk Audio EL34 Vacuum Tube Amplifier Class A single-ended
    • Option B Luxury Aiqin L-02 HIFI EL34
    I'm looking for some insight and opinions on which one would be better for my setup (posted above) within the context of classical, noise, post-punk, and afrobeat.
    David
  2. Poultrygeist
    Poultrygeist Lunatic Member
    I'd go with the one from Amazon. If for some reason you're not satisfied you can return it and they'll pay the return shipping.
    Plus for a few bucks you can buy their extended warranty.
    You do have recourse with an eBay purchase but it takes some effort.
  3. Stefan Wood
    Stefan Wood AK Subscriber Subscriber
    296
    Herndon, Virginia
    You might want to complement the speakers with a subwoofer for the non classical music. The post punk and afrobeat may lack that bottom end.
  4. David Politi
    9
    Thanks everyone! I ended up chickening out and ordering a MP-301
  5. Stefan Wood
    296
    Herndon, Virginia
    It is a better amp.
  6. Dr. Ears
    Dr. Ears New Member
    48
    Colorado Springs, Colorado
    I am fairly certain they come out of the same factory. I would choose the one by Amazon because of customer service and the extra driver tube.
