Denon DP80
Discussion in 'Turntables' started by Legrace, Feb 13, 2018.
  1. Legrace
    Legrace Active Member
    206
    Ontario, Canada
    Will be marrying with a DK-110 plinth. Hoping for good results.
    matteos, fiddlefye and fishondwan like this.
  2. Hajidub
    Hajidub Chihuahua/Pug = Chug Subscriber
    5,619
    Colorado Springs, CO
  3. Northman
    Northman Active Member
    451
    Grand Forks, ND
    Pics or it didn't happen!
    JJCalvillo and dosmalo like this.
  4. fiddlefye
    fiddlefye AK Subscriber Subscriber
    So what band did you hire to play at the reception? What tonearm is in the relationship? Ooo, that maybe gets a bit kinky...
    TENER and matteos like this.
  5. Legrace
    206
    Ontario, Canada
    Found a drive unit locally but ended up having to go to Japan for a plinth, the waiting game begins. Hopefully it arrives intact, I've seen some of the horror stories. Arm is TBD. I have an AudioMods V that I think could be a good match, but at this time not ruling out investing in something a bit longer.
  6. sturgus
    sturgus AK Subscriber Subscriber
    439
    SAINT LOUIS
    Good luck with the table. I have a 75 on my radar. Very nice tables. I just have to decide if I want to sell my DP-59L to fund the purchase. Let us know how it goes.
    matteos likes this.
  7. majick47
    majick47 Addicted Member
    8,609
    Pembroke MA
    Legrace I'm sure you are aware that if the DP-80 doesn't come with one you will need a step down transformer 120v to 100v. Too bad there wasn't any plinths available locally in the US.
  8. belyin
    belyin Member
    63
    New Orleans
    Well, if I can't get my DP75 fixed (runaway speed problem--my tech thought he could fix it, but it has been a year so time to get it back and try someone else!) I have one of the big DK2000 double arm plinths . . .
    fiddlefye likes this.
  9. Legrace
    206
    Ontario, Canada
    Thanks Sturgus. Looks like I'm headed for an all vintage DD future. I have one BD in my current mix, but have a couple complaints with it. Admittedly its only a mid tier model and going up the range would address the negatives, but a TOTL belt drive like the Rega RP10 is more money then I care to part with. Consequently more and more I find myself defaulting to vintage options.
    majick47 - thanks, yes well aware.
  10. bimasta
    bimasta Super Member
    3,003
    To some this idea may be heresy, Legrace — but I use my DP80 with NO plinth. Here's a snapshot...
    The arm is a Syrinx PU3. (The gizmo to the right of the arm-bearing is a VTA adjuster I'm experimenting with; I copped it from a Zeiss lab microscope). Your Audiomods arm will be fine — yes, a longer arm has some advantages (and disadvantages) and looks better on this TT due to its large diameter — I want one too, but it's not a necessary expense.
    You can try yours "plinthless" if you like — the TT's bottom is flat and stands firmly on its own, as the pic shows. I like the minimalist look, a friend calls it "Starship Enterprise". Some may hate it. It also takes up far less space.
    Another heresy: it doesn't NEED a plinth. A plinth does NOT dampen resonances, it's just an easy way to mount tonearms — and it's "traditional", some people like traditional.
    If you want to try it, you'll need to make an armboard. Real easy. I made mine in about 45 minutes. You can only see a bit of it peeking out, 60% is hidden by the flange, where it's secured to the TT with absolute rigidity. If you want to experiment, I can send you the armboard template.
    Ken Boyd, matteos, ateal and 3 others like this.
  11. fiddlefye
    I think it looks pretty cool.....
  12. Legrace
    206
    Ontario, Canada
    Wow thanks. That actually looks pretty sharp. Would most definitely love to have a copy of your template. When the plinth finally does arrive nice to know I could also sell it on if I so choose. Always better to have options!
  13. bimasta
    3,003
    Will do. It'll take a few days to get to it. As mentioned, really easy. I used a scrap piece of MDF, cut a curve, drilled a hole, and sprayed it black. Obviously some calculations were involved, eg pivot-to-spindle distance, but not difficult. The template was made for the Syrinx, but by lucky happenstance also fits a Linn Ittok. Your Audiomods might need the hole to move 1mm or 3, and maybe a different diameter (Rega base, right?) and that'll be up to you.
    MDF was just convenient, but "sounds" fine, and very little of it shows so Krylon basic black looks ok. Like you, I'll be fitting a 12" arm soon, and I have some gorgeously grained Brazilian hardwood for that, because more of it shows — but it's an indulgent touch of luxury, not a necessity. And who knows, it may clash with the DP80's perfect spartan look.
    Anyway, I'll send you the template as soon as I can get to it. At least you can mount the arm and play the turntable while waiting for the plinth from Japan.
  14. Legrace
    206
    Ontario, Canada
    Cool, thank you so much. :beerchug:
  15. Legrace
    206
    Ontario, Canada
    The saucer has landed, what a beautiful beast!
  16. bimasta
    3,003
    Yes, it really is gorgeous. I don't like the big flange so much (it isn't ugly, just big) but it's necessary, it hides all the control circuitry — Form meets Function. It doesn't need an outboard power supply/control unit with a fat umbilical, like my DQX-1000 has. The DQX is a little more sleek, but that outboard box is a hassle, and you have to find a place to put it. And I hate the feet on the DQX — the DP80, as I have mine set up, doesn't need feet, it just seems to "float" in space. And it takes up so little space.
    Will you use your Audiomods arm?
  17. Legrace
    206
    Ontario, Canada
    That's the current plan. In terms of your mini plinth assume it attaches to the 2 rearmost attachment points and maybe has an inner arc matching the body across that distance? Which would anchor it tightly. Keen to try out something like that out.
  18. Legrace
    206
    Ontario, Canada
    Closing the loop re how things turned out in the end...
    When the plinth first arrived from Japan my initial reaction was shock. Shock at the size of the shipper. Double boxed maybe? No, simply put, the DK-110 is freaking huge. o_O
    Here it is with everything mounted, incl the new armboard I prepped for the AudioMods V. Adjacent is a Dual 721, lending perspective to my comment above.
    How does it sound? :eek2:
    Been an interesting journey. Started out with a "needs to last me to the rest of my days" BD model in which I invested a lot of dollars in upgrades, but could never quite seem to get dialed in the way I wanted. Now its 3 x DD models and a feeling I've finally arrived. Appreciate the other two, but the Denon is the undisputed :king:
    hoodie, fishondwan and fiddlefye like this.
  19. EngineerNate
    3,479
    That tonearm is gorgeous. Great match to the big Denon.
  20. Legrace
    206
    Ontario, Canada
    TBH have been toying with idea of replacing with a 12" SME. Should I leave well enough alone? Opinions from the experts?
