dneu201
Well-Known Member
My Denon PRA-1500 Preamp I found at a Goodwill for $20 5 months ago just started having issues yesterday. I hooked it back up after 2 weeks of no use and noticed the right channel was playing awfully quiet. I checked my connections on the back of the preamp and cranked the volume. Sure enough the right channel started working again, but as I experimented and turned the volume down/unit off then back up/on, the right channel went quiet again and would start to crackle and distort at 3/4 volume. I opened up the unit and inspected everything, cleaned the pots again, blew out where I saw some dust, but had no luck. I checked the headphone out and it played perfectly with no issues. I noticed the voltage regulators were getting VERY hot while feeling the different components in the unit and narrowed it down to one specific one causing the heat. I went ahead and ordered two of the three regulators off Mouser, but am struggling to find the last one available that doesn't have to be purchased in bulk.
Here are the the regulators:
1. NJM78M18FA - Purchased off Mouser (18V .5A 3 terminal)
2. NJM79M18FA - Purchased off Mouser (but had to purchase NJM7918FA which is 18V 1.5A instead of .5A)
3. NJM78M15FA - Can't find this one available
Based on the issues I am having, does it seem like these regulators can be the problem and if I was to remove them, how can I easily test them to see if they are faulty?
Thanks.
Thanks.
