Deoxit vs. CRC Contact Cleaner vs ?
Discussion in 'General Audio Discussion' started by AudCrshDumy, Jan 20, 2010.
  1. AudCrshDumy
    AudCrshDumy Well-Known Member
    858
    Not Far Enuff W of DC
    Well, I'm about to embark on my 1st deoxit attempt on my Marantz 1250 vol pot. Is this stuff different/better than contact cleaner ?
  2. Urizen
    Urizen Lunatic Member
    24,636
    Accept no substitute. :)
  3. AudCrshDumy
    858
    I hear that...will read the deox Thread too b4 hand.
  4. Chatta
    Chatta Active Member
    162
    It looks like the deoxit has more good reviews, (or a better marketing campaign)
  5. austi15
    austi15 Super Member
    1,033
    Silver Spring, Maryland
    I haven't tried any other, but DeOxit works great for me.
  6. poseidon8118
    poseidon8118 Active Member
    185
    NW Indiana/Chicagoland
    I use CRC QD Contact Cleaner with great success. I would like to try Deoxit in the near future to see which I like better.
  7. archie2
    archie2 Addicted Member
    6,171
    Almost Coastal RI
    I've used CFC with good results. And it sprays upside down. But I use DexoIT exclusively now.
  8. RickB
    RickB On the Road to Find Out
    2,252
    San Antonio, Texas
    Actually, Caig's FaderLube is the best thing to use on pots and moving contacts....or at least use it after using the DeoxIt....
    In the nearly five decades that I've been messing with electronics, the Caig solutions are the best things that I have found that's still around since the demise of Cramolin and Freon TF solvents...man, I miss the days of buying a 30lb. jug of R-11 for twenty bucks or so...I used to use that stuff like water....
  9. AAA3330
    AAA3330 Super Member
    1,820
    Northern Illinois
    I'm not comparing this to Deoxit by Caig, because I've never used the Deoxit brand, but I've been using a product called "Jiffy Bath contact cleaner" by "GC Electronics" for quite some time and have always had excellent results, so see no reason to change. At my local distributer, the Deoxit brand is six times as much as the GC, which is important to me because I go through a lot of it.
  10. dew042
    dew042 Honky Tonk Hero Subscriber
    5,342
    Northeast Minneapolis
    CRC Contact Cleaner dries up and is gone, Deoxit leaves a residue to condition and prevent corrosion. They are really different.
    dew.
  11. mfhale
    mfhale Super Member
    3,491
    Houston
    I've used both to good effect. DeOxit may be better at preventing future outbreaks, but nothing ever stays in use long enough for me to have judged it.
  12. AAA3330
    1,820
    Northern Illinois
    I've always thought of CRC as more for automotive use. Corroded connections, etc. I personally wouldn't use it on my sensitive electronic equipment.
    Oscar23 likes this.
  13. PacificStereo
    PacificStereo Super Member
    1,725
    The CRC is fine to use on electronics, but one needs to remember that it is a contact cleaner, not a contact preservative. It's great because it doesn't leave a residue (Oh, I long for the days of TF, like RickB says- I still have a few cans and small containers of liquid TF), but for switches and pots, some protection makes for a much more reliable result. I typically use the DeoxIT first, then if necessary follow up with Faderlube (the DeoxIT itself is an oil, so it does have some lubricating properties of its own).
  14. DrMux
    DrMux Welcome to the Gig.
    851
    Drexel Lake, SC
    It's actually made just for sensitive electronics like .....
    Formulated for use on precision instruments,
    equipment and components
    Safely cleans plastic surfaces, magnetic
    and paper tape components
    Effectively removes dust, lint, and light oil from tape heads,
    tuners, and sensitive equipment
    Non-conductive
    Cleans and degreases points, contacts, switches,
    relays, plugs, printed circuits and diagnostic test equipment
    Evaporates quickly and completely
    Harmless to most plastics
    Leaves no residue
    Contains no CFCs
    If you want to clean a board, pots etc spray it on heavy. It dries real quick and will take off the heavy gunk. Then use the Fader Lube or coating products if that's your thing. But this stuff works excellent for first time cleaning of old vintage gear without taking it apart. Been using it for years on my cars and mostly guitar amps to include tube amps. And most of all it costs less than most others.
  15. ke4mcl
    ke4mcl Super Member
    3,745
    miami fl
    SHIELDS UP!
    i use wd40. every audio piece i've ever restored has had wd40 on it somewhere. be it pots, tube sockets, dirty switch contacts, etc. some of you may cringe at this thought but hey its worked for me and on pieces i use daily for hours on end.
  16. mashaffer
    mashaffer Super Member
    3,358
    North Central Indiana
    So is CRC QD safe for pots? I used it to great effect on switches in my Baldwin organ but was not sure how it would be on pots so just used fader lube.
    mike
  17. cgutz
    cgutz AK Member
    3,404
    SE South Dakota
    WD40? Might clean ok, but it is a solvent, and softens and degrades plastic and rubber.
  18. hpsenicka
    hpsenicka Moderator Subscriber
    5,518
    west of Toronto, Ontario
    :nono:
    Every product has a purpose... but using WD40 to clean/lube pots seems rather risky.
    I can see using it as a cleaner to loosen crud on a PCB, but not on my delicate pots, please.
  19. budgetaudio6
    budgetaudio6 Addicted Member
    5,762
    I use CRC and deoxit...infact ive got a couple of ounces of deoxit some where. and two 5 ounce cans of CRC. i use it for pots, hosing down circuit boards.
    Deoxit is great, but very expensive for the small amount they contain.
  20. tarior
    tarior Dirty pool, old man? Subscriber
    6,578
    Kelso, Washington
    When I get a pot that's very stubborn about coming clean, I'll just hose it out thouroughly with CRC (or similar) and then follow up with Faderlube F100. For switches it's usually D5 or D100, and DN5 for most pots. Header pins and other plug type devices get G100 (ProGold).
