Looking for recommendations on a DAC to use as a DAC/preamp for a desktop setup with a dedicated power amp. I want to avoid separate a DAC and preamp to minimize the component chain to the speakers. Not looking to spend more than $300-400. Used is fine.
In my (relatively short) experience as a frugal audiophile, I've come to believe that buying older/used hi-end speakers and components yields the best sonic results. I also believe that Chinese and DIY made stuff is some of the best bang for buck stuff out there.
I'm currently using a Stoner Acoustics UD120 dac with a Gemtune 300b integrated tube amp with MB Quart Vera speakers. The Chinese Gemtune 300b amp is friggin' awesome and wholly recommend it as well as the speakers and DAC.
I recently came into an older McCormack power amp that drives the speakers wonderfully, and although not quite as tantalizing as tube amp, it suits higher energy music better. With this new component, I'd like to combine DAC and volume control without using a device/DAC that employs a headphone amp. This has been hard to find.
If the options aren't great, I'm also considering looking for an older A/V component that uses the Burr Brown PCM 1792 chip as a DAC/preamp.
