After watching auctions for a year, I was able to acquire a replacement mid-high and tweeter to replace the non-functioning ones in one of my ML-1C speakers. However, there are no obvious indications as to polarity on either the old or new ones. I know with woofers you can use a battery to determine polarity, but I don't think that trick will work with the mid-high and tweeter. Does anyone know if McIntosh had some convention regarding marking the drivers in some non-obvious way, or otherwise suggest a safe way to determine polarity of these them, short of installing them and listening? I would prefer not to do the install and listen procedure to avoid having to pick up the soldering iron too many times. Also, is the thin gasket on the mounting plate of the mid-high driver essential? I was unable to successfully salvage the one on the old mid-high.
Thanks
Thanks
