SLQD - I don't think so - but best to contact Kevin at KAB and ask...
The CW damping method is the same as is used to control cantilever resonance in the Shure V15IV...
(described in some detail in the shure technical seminar paper
http://shure.custhelp.com/app/answers/detail/a_id/4072)
The energy of the main resonance causes the CW to move and to generate its own resonance - which is carefully calculated to be a resonance that cancels out the main resonance - very nice! - but it leaves the CW resonating - and measurements of this approach show two smaller resonant peaks where previously there was one.
In the Shure cantilever version of the same, the CW is seperated from the cantilever by specially designed damping materials (elastomers) so the difference in motion between CW and cantilever results not only in cancellation but also in conversion to heat and therefore absorbing energy out of the system.
This was also used by a number of other brands in their CW's eg: Dual.
It is worth reading Pierre Lurne's comments on his tonearm designs ... he is deadset against any form of isolation/seperation of the arm from the CW, and in fact designs the CW in his arms to bolt to the arm in a manner that makes it a single piece.
He points out that any form of seperation / isolation here results in multiple vibrations rather than a single one, and that the more vibrations you have floating around in your system, the harder it is to design a solution that eliminates them.... (it is impossible to totally isolate the CW while still having it execute its function as a counter-weight.... and therefore the damped connection still involves transfer of energy in both directions....)
So even the standard CW mountings - which usually use some form of plastic as the inner surface up against the metal of the armtube, are a negative as they do in fact provide a degree of isolation and therefore an environment that generates additional seperate resonances (albeit at a very low level).
Anyway the short version of all this, is that semi-isolated anti-resonant CW's do work, and work well, but they are also a compromise solution, and perfectionist high end arms don't appear to use this method.
bye for now
David
