yeah,i am familiar with upgrades as i have done them on KG4s,and i know they are different from ls lls and lllsLOL everything? All drivers and crossovers are different from H to H2. What did you get? Heresy or Heresy 2? The upgrades are generally within the model not from 1 to 2.
fair enough,i now know i have the l but how do i know early or late...i see there is a # stamped on the back of these and might mean the newness.Hersey were continually upgraded over the life span. So there is no simple answer. The last I is very close to the first II. Where the early I is very different from the II's.
Personally I prefer the series 1 over the later models, I have two pair, raw birch, and oiled walnut, the birch have been modified for biamping. The crossovers seem to be indestructible, both of mine have the original components and sound very schveet.I just need to know as i just bought a working pair for cheap and might need to upgrade crossover or diaphrams in the future...they "sing" right now,lucky me.
ok,so i picked up a pair of heresey 2s also and they dont seem to be as bright as the 1s.........hmmmmmmmm,any thoughtsLOL everything? All drivers and crossovers are different from H to H2. What did you get? Heresy or Heresy 2? The upgrades are generally within the model not from 1 to 2.
yes,there is high end coming out of the tweeters but it seems like too much not a bad sound but i think the 1s go a little lower in frequency than the tweets on the 2sHard to say. The tweeters are different as is the crossover network. Check and make sure the tweeters in the II’s are both working. It’s not uncommon to find a fried diaphragm. Good news is it’s an easy fix and diaphragms are readily available.
what did you notice the difference was between the l and llPersonally I prefer the series 1 over the later models, I have two pair, raw birch, and oiled walnut, the birch have been modified for biamping. The crossovers seem to be indestructible, both of mine have the original components and sound very schveet.
Better tighter bass, more alive sounding. The difference was not night and day, but I think the difference could be attributed to whatever makes the series I almost 20 lbs heavier, though both are rated for the same 50hz, where the series three are only 58hz, and the weight of the third series is about half way between the other two. All of the above info from the Klipsch Web site.what did you notice the difference was between the l and ll
Nope.Been looking at a set of Heresy II's.. seller says they are 4 ohm... Always thought these were either 6 ohm or 8 ohm? Never seen a set of 4 ohms, did they make such a animal?
