arossphoto
I'm planning to do some work on a Sansui AU-D11 integrated amp and getting all my tools together first. I've been reading about Dim Bulb Testers, but I'm confused about what wattage bulb to use. I've read that you should use a bulb that is 1.5-2 times the wattage of the device being tested, but are they referring to the power output or the power consumption?
The output on my amp is 120wpc and the power consumption is 600 watts, so what wattage bulb should I be using? Is 200watts going to be enough?
Thanks.
Thanks.
