A gentleman dropped this off to me today to see if I could fix it (sentimental value), there are no lights when switched on, but there does seem to be power going through the unit so I don't think it's the transformer.
It's a 240V unit, on DBT (77W), I'm reading ~202V at the switch while it's off, drops to 156V when on.
There's idle voltages at the emitter resistor measurement points on both channels, which seem to change OK with the adjusters too (~10mV).
No relay click. I'm not seeing any burnt flameproof resistors on quick glance, and the outputs don't seem to be shorted either.
It's very dirty and there's a lot of corroded jumpers etc, could it just be possible that the LED drive circuit is messed up (along with whatever else)? Is it worth removing the obvious corrosion and DSBG before attempting to move forward with it?
Appreciate suggestions
