Hi all, I am stuck a bit. I worked on my smaller Marantz receivers before (mainly 2250 and 2238), but this one is just stuffed inside that small case.
I have some electrolytic caps visibly leaking on the power supply board, so now the voltages that go to the protection board seem too low and relay coils buzz (and barely close contacts).
Is there an easy way to unscrew that board without removing the right amplifier board beside it? I can't get to to the bottom bolts that hold the little heatsink on the side (tuner cover blocks those).
Thanks!
Thanks!
