shelly_d
Not An Audiophool
I am starting a new thread for this opinion to avoid carping on another ongoing thread on this forum. The idea that the power cord can make an audible difference in what you hear. Understand that between the power cord and the amp circuitry is a power supply that will isolate the power cord from the amp. That power supply contains a transformer, rectifier, filtering caps, sometimes a filtering choke and sometimes a voltage regulator. Any subtle changes that a power cord could create (and I dispute that they can) are lost in the intervening circuits. It's a power cord folks! Nothing more.
What's its job?
It carries the line current from the outlet to the power transformer. What could it bring with it? First you can consider RFI/EFI from outside. Well that's going to be what is called common mode noise, that is induced across BOTH the hot and neutral leads. The transformer responds to the DIFFERENCE between the two leads so that won't make it through the transformer. Then there is the noise on the incoming line that is different between the two lines. That's there at the outlet. The power cord simply transports to the power transformer, so unless there is a power conditioner built into the power cord, the cord can't do anything about that. Well, then there is the claim that the outlet can grip the cord better. Well here there could be some claim. The outlet and the IEC connection has to be solid and secure to be safe. If the plug is loose in the outlet that is a problem and needs to be fixed for both audio quality and safety. Best fix - replace the outlet so that ALL devices plugged into the outlet are held securely. Get a Levitown for $5 ~ $7 (probably overpaying) at your local hardware store. Once you have that and you are gripping the plug well, any further "improvement" won't improve sound quality. Why is that? There is a physical connection between the outlet and the plug. It contributes, usually, less then 1 ohm resistance between the power feed and the cabling inside the power cord. Assuming that your amp draws perhaps 1000 watts at high power, that is about 8 amps peak. At a full 1 ohm resistance (really quite high for the connection) that represents 8 volt drop across the plug. Now lets say you improve the cable and manage to drop that resistance down to .25 ohms. (That's a huge change for something like this). Now the voltage drop is down to 2 volts. So you now have a 6 volt change feeding the amp. At 120 volts a 6 volt change represents a 5% voltage change. The standards for power delivery allow that much change across the full range of their transmission systems. That is, if your voltage is anywhere between 115 volts and 125 volts your power is normal. Your amp is designed with this variation in mind. If you have a voltage regulator in your power supply, by providing the increase in voltage, you increase the load on your regulator circuit which just dissipates the added voltage and resulting power as heat and never affects the amp circuit at all.
But what about all the people who say they hear a difference. Here is some real facts from human sensory research. The one sense that we have that has the shortest retained memory is hearing. The one sense that is easiest to influence by presuggestion is hearing. If you read or hear that the treble is going to be improved, you will start listening to the treble more closely and notice more even when there is not change. That's just the way we are. All of us. Its not that we are weak minded, its that we all have this suggestibility. Marketers know this and depend upon 2 things, one that its true (and it is) and that most of us do not know about it and allow for it when auditioning new equipment. Therefore if say Wattgate claims that their power plug will do wonders for your stereo for just $77.90, and that you will hear the difference, they are depending upon the suggestion that things will be better to influence what you listen for and therefore what you hear. (http://www.revolutionpower.com/p/WATTGATE+330i+Audio+Grade+Gold+Black+Connector+Plug/310/) This is not to say that you are not hearing what you think you are hearing, far from it. What is happening is that you are noticing the particular qualities more after the install simply because you are listening for them after the install. In short its a game played by marketing operations to separate you from you money.
I know this is a controversial opinion and I invite opposing viewpoints. Please do not get personal. This is about the so called audiophile power cord industry and their marketing tactics.
To those who would like to learn more about that human sensory research that I mentioned. I am truly sorry but I remember reading about it some time ago but I no longer remember where or how I stumbled across it, so no, I am sorry, but I cannot post links to it. A glaring defect in this post and I apologize for their absence.
Shelly_D
What's its job?
Shelly_D
