swechsler
Frog Whisperer
I picked up this JBL 128H cheap on Craigslist, figure I'll probably end up flipping it but thought maybe I'd play around with it a little first.
The woofer was refoamed by a previous owner. The foam was correctly attached to the back of the cone, and the voice coil is correctly centered (it appears that shims were used since the dust cap was replaced). However, the cone naturally returns to a position lower than it should be. In this position the spider is concave and incoming excursion is very low. What I'm wondering is if this could be caused by the surround being installed incorrectly (although I don't see what could have been done wrong unless an incorrect surround was used), or is the spider permanently formed into that position. If the latter, is there any way that it can be fixed? How can I determine which it is, short of cutting the surround?
