Wardsweb,
Since I'm in Japan I couldn't figure out what the heck was primer or sealer or paint and my wife wasn't around to translate.
I ran a sander across once with 100 grit, again with 240 grit then rubbed in a coat of black poly to let the paint soak in a bit and give me a base to work with.
Topped it off with three light coats then applied the stickers after about 6 hours. 1st and 2nd coat must have been about .5 mil and the finish coat probably was around 1 mil. Total thickness I'm guessing was just over 2 mils taking into account what was rubbed in
I did a tape test with some 3M tape that adheres with 40 lbs per square inch and snatched it off. No paint failure. Same standard we use for planes that fly Mach 2. Hopefully these horns will never hit mach, but if they do the paint won't peel.
Thanks for the nice comments.
John
