Amen, brother! Okay, here's a simple cheap one from Allen Wright. Buy a spool of reeeely skinny solid-core wire, like 30ga. Cut three lengths about 1.3 times desired finished length. Attach the midpoint of all three to something, and BRAID all three wires together. Keep it neat and even! Finished with one side? Flip it around and do the other half. Slip on some pieces of shrink tubing, solder the connectors on (defy convention and use light, thin, unplated ones), use the shrink tubing to reinforce the point where wires meet phono plug. Don't forget to use an ohmmeter to get connections right if you only use one color. Oh, and there are many things you can do with the third wire: ground at one end only!Originally posted by stewey
I'm looking for a low cost alternative to otherwise ridiculously priced quality cables.
I don't know if I'll go to the extent that Wardsweb did. Primarily I'm looking for a low cost alternative to otherwise ridiculously priced quality cables.
