re: "Tube watts"... somebody has to address this
One "tube watt" RMS IS the same as one "solid state watt" RMS... the difference is the way tubes overload as compared to transistors. A tube amplifier IS a compressor... as the input voltage increases, the output will compress as it distorts, such that the sound's character will change, but you may well not be consciously aware of (harmonic) distortion. When typical ss amps "hit the rail" (all the P/S voltage they have to give), the clipping is agressive and audible... as well as dangerous to sensitive loudspeaker drivers.
Another, not unrelated issue, is the harmonic character of tube vs. ss distortion... but I don't want to go down that road right now.
I routinely use a ca. 14 WRMS per channel Magnavox EL84PP amp with a pair of the nortiously inefficent AR-3 acoustic suspension speakers. Common wisdom will tell you NO WAY is 14 WRMS enough for these power-hungry speakers, but I listen near field (say within less than 10 feet) and I think the combination sounds just dandy. I wouldn't recommend trying a 15 WRMS ss amp (say a Pioneer SA-5500) with AR-3's!
The eBAY PCB looks very cute... Another cute kit amp is the 11MS8 PP stereo amp on a board made by S-5 Electronics (
http://www.s5electronics.com/gpage1.html) and also sold (with 11BM8 tubes) by Antique Electronics Supply (
www.tubesandmore.com). This is a good sounding amp (8W per channel) and very easy to build. The only drawback is that the tubes run quite hot, so I don't know how long they'll last, and one has to be careful to provide adequate ventilation.
Another WHOLE topic is whether one really needs inefficnent speakers and high-power amps at all... My main amps are 3.5 watt monoblocks, but my speakers are ca. 100 dB and the system does the job quite nicely.
