Well, the 6V6 is a power tube, that'd make a good amp if you've got a few of 'em (and those kinds of amps are fairly common so it's easy to find examples and schematics). The 6AU6A can be used as a driver for the 6V6 (check
here for an example). The 6AV6 I believe *can* be used as a driver tube as well if you hook up the triode section... IIRC the triode section is very similar to the commonly used 12AX7. It would be somewhat of an odd design for a first project, though. The 12AT7 is also a driver tube, but it's rarely used in hifi applications because it's somewhat ill suited for the task. It's used in a lot of Marshall guitar amps, though. I believe the 12AT6 is similar, but again it's prolly not a very good choice for a hifi amp. The 35C5 is a power tube, but it's low power (maybe 1 watt or so output) and it's designed for use in amps without power transformers, thus making a hot chassis. It'd be easy to design an amp with that one, but you prolly wouldn't be satisfied with the end result, and it can be dangerous working with a hot chassis. The 5U4's are rectifiers, the 5V4 is a better rectifier IMO. I have no idea what the 1B5 is. Most of the rest of those are either IF or RF amp tubes, designed for radio and TV tuner sections.
Now... out of all those, for a first amp, I'd prolly recommend the 6K6 if you have enough of 'em. It's a rather unothodox design, but it would be pretty simple to wire up and I think it would sound quite good. Use the triode section as the driver and the pentode section as the power amp. No need for separate driver tubes. Check
this out, it's not exactly what I'm thinking about, but maybe one of the more experienced tube builders could help you with a design.
Edit: BTW, is it at all strange/sad that I'm 20 and I knew all those tube types off the top of my head? :saywhat:
