I have a homebuilt 20WPC Class A amp that I'm finishing up, and I need some wood panels cut. The local Lowe's has nice planks of both oak and birch. The cuts are fairly simple, but I've had bad luck messing with oak in the past...was just too dry and tried to fall apart on me.
So I'd really like some opinions from some of you all that work with wood more than I do...was the oak I used before just bad stuff? Isn't birch easier to work with?
I worry a little bit since at a couple of places I will have a thin section of about 1/2" wide by 2" long. It will be reinforced from behind once it is assembled, but I envision that oak I cut way back when and how it nearly fell apart, and couldn't imagine trying to cut a piece a half-inch in width. Maybe a normal piece wouldn't be bad, but if all oak is like that then I'll go with the birch.
The oak would certainly look cooler, but I'd love some opinions... :scratch2:
