Do some audiophiles really prefer flat frequency response?
Discussion in 'General Audio Discussion' started by Extremesam, Jun 11, 2018.
Thread Status:
Not open for further replies.
  1. Extremesam
    Extremesam New Member
    38
    I've read that some audio purists frown on tone controls and equalization. I've tried to listen to music with a flat response and to me it just sounds awful. Transistor radio-like. It's been proven scientifically that some frequencies are easier heard than others to the human ear. So then why would anyone choose a level graph over something that really sounds good? Especially if you have good equipment that can really make it come to life. I'd love to hear from the purists and anyone with your thoughts on this. .... Sam
    labios, triode17 and KDAC like this.
  2. botrytis
    29,403
    PODUNC USA......
    I don't have any tone controls and will never use them. Tone controls can only adjust for small problems and cause other issues.
    Ever think it is your equipment or room set up that is the problem?
    Extremesam, Hyfi, bobva and 7 others like this.
  3. nj pheonix
    10,157
    New Jersey
    Well you were listening to the same frequencies live and you found them appealing. Nothing wrong with tailoring sound to please your ear. In a perfect world what you recorded should sound the same when its played back.
    Extremesam and Audiovet like this.
  4. WillVT
    WillVT Super Member
    1,124
    Burlington, VT
    Theoretically, all that equalization should be done in the recording and mastering room. Therefore, some would say if your system is good enough, no further changes should be made, and you are hearing close to what the engineers/artist wanted you to hear.
  5. sKiZo
    You assUme you're hearing flat response if you don't use tone controls or equalization. Not necessarily true, as the room and environment can change the frequency response significantly.
    Add to that ... flat response actually sucks, as the normal human ear attenuates or boosts different parts of the frequency spectrum. Application of EQ in the form of a "house curve" compensates for this for a more natural sound.
    PS ... bad EQ sucks, and bad EQ is any tweaks that aren't based on actual physical testing of the system. No excuses either - what once took a room full of pros with some fancy gear can now be done with a laptop, calibrated mike, and free software ...
    F0427ea1, ev13wt, Extremesam and 9 others like this.
  6. Dave1384
    Dave1384 Stuck in the 70's
    3,576
    Suburban Philadelphia
    No. No.
    There are 6 restored Pioneers here. Every one of them demand help from an eq , sometimes even a parametric. Plus all my speakers have different sound properties. Flat signals sound nasally.
    I agree 100 percent with Sam.
    F0427ea1, Extremesam and Djcoolray like this.
  7. goodolpg
    goodolpg Just an old fart trying to help.
    But my hearing isn't the same as theirs and neither is my room or gear.
    Extremesam, Denten, Audiovet and 3 others like this.
  8. grillebilly
    grillebilly Empty Head Subscriber
    16,254
    Fairfax VA
    I messed with equalizers and tone controls for years. It makes the music sound different but not really better IMO. Now it is straight up, how the engineers wanted it to be. Unless your playback is faulty.
    Alobar, stish, GChief and 3 others like this.
  9. 62caddy
    9,690
    NEPA
    The better the system, the less correction is generally needed.
    A really good system should not sound anything like a transistor radio - even when all tone controls are set to flat.
    cnolanh, armyslowrdr, stish and 11 others like this.
  10. petehall347
    28,253
    uk.. the middle bit
    i adjust to what sounds right to me .
    F0427ea1, Alobar, Bdbras84 and 9 others like this.
  11. quiet
    quiet AK Subscriber Subscriber
    2,473
    arkansas
    I'm not a purist but do have thoughts on this. It appears the objective is to eliminate the sharp hills and valleys. For me this is a resemblance of flat response.
    I'm not using any tone control. Just lucky I think. Or maybe it doesn't help.
  12. Extremesam
    38
    Thanks for the replies everyone. Very helpful. To elaborate, I have found that even while using quality headphones or earbuds that I cannot listen to flat response curves. Does anyone prefer a flat response while using these? More please.'... Sam
  13. imral3
    imral3 Super Member
    3,136
    Blackwood, New Jersey
    Too much typing... pass.
    Hajidub and Darren James like this.
  14. imral3
    imral3 Super Member
    3,136
    What is your source for material?
  15. Extremesam
    38
    I'm close to it. Just a few db's of bottom end a little at the top will do it.
  16. Extremesam
    38
    Indeed!
  17. Extremesam
    38
    Well said
  18. Extremesam
    38
    If we had bionic ears flat response would sound right.
    woodj likes this.
  19. Extremesam
    38
    Digital files from a DAC
    imral3 likes this.
  20. tubed
    tubed Lunatic Member
    15,872
    Aztlan
    Good recordings sound relatively good on any system and in any room, flat or equalized.
    Transistor radios excluded;)
    62caddy and Roadrash like this.
Thread Status:
