Where did you get your vellum? I got mine at Walmart. Hobby Lobby also had single sheets of the same weight. 15 sheets of 30 lb vellum at Walmart, but I had to double it in order to minimize the spot lights effect. I couldn't find 50 lb vellum anywhere.
Sorry to derail the thread, but how do you remove the knobs? Thanks.
I believe standard practice would be to use 2 spoons. With the curved side of the spoon against the faceplate (so you do not scratch it) exert force back and forth and a lot of times they just pop off or are loose enough to easily pull off. LMK if this works for you.
I've used the 2 spoon method before with success, however, Catrafter has an even better method.
Here's a 4270 that I replaced all the lamps in and used the wax sheets from a box of KFC biscuits. Yummy biscuits, and a cheap and good looking dial.
Damn nice looking job Pat. :thmbsp:
Is there vellum behind the meters on the 2285?
